rod ends for tie rod?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by misfit, Jul 11, 2001.
  1. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    what are the pros and cons of using these instead of regular tie rod ends.
  2. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    I'm not sure I understand the question.
    <A target="_blank" HREF=http://www.chriswhitley.com>http://www.chriswhitley.com</A>
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I think he's asking about using heim joints instead of the standard "ball joint" type of tie rods ends. Heim joints will provide a huge range of motion for rigs with radical articulation. But they aren't protected from the elements and wear out very quickly. Tie-rods have rubber boots to keep grease in and dirt out. I've never seen a heim joint that was truly meant for dirty environments.
    <A target="_blank" HREF=http://www.angelfire.com/super/ThunderTruck>http://www.angelfire.com/super/ThunderTruck</A>
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Do you mean something like Heim joints? One thing you might want to look into is if the tierod will clear the leaf springs because they don't have "drop" built into them like the stock ones. Also you would have to have the taper drilled out in the nuckle so that you could use bolts to conect them. But they are stronger (depending on size). I am thinking about doing this some day when I do the cross over steering.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  5. BigTex
    Dec 27, 2000
    974
    South Texas
    Gotcha. I would definitely not use those on mine since it is my daily driver.
  6. K5RON
    K5RON 1/2 ton status
    Apr 14, 2001
    219
    Misfit,
    I've used rod end for a clutch linkage for about four years now without a problem. The linkage is in direct line of the front tires, so they catch a lot of "GOO" They do make ones with seals and even the ones without have teflon to "wipe" the ball clean. One word of advice, "Don't go cheap"! Buy the best one's you can afford. I personally like the one's I believe are called Black Max. Or buy the three piece chomemoly ones.HTH
    Ron
  7. misfit
    Jul 21, 2000
    324
    the main reason i might use heims will be to clear my own rockrod: my tie rod goes in to the knuckle from the top and it looks like i might hit t he tie rod when my springs compress, using standard 7/8 TRE. i know that i couldnt get my huge tie rod installed with thhe truck sitting on the ground, not enough room to manipulate the tie rod into position
