roll bar mount
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Chris_T, Dec 1, 2001.
  1. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    I have a 72 Blazer with the Smittybuilt rollbar kit. The bar mounts to the floor and has provisions to be bolted to the bedsides as well. The front hoop is about a 1/2" too low for both the side tabs and the rear supports. I have a roll of 1/2" thick rubber from McCoy bros, similar in density to heavy duty mudflaps. In the short term until I can get a full cage welded up, can I use this to raise my bar 1/2" and isolate some of the vibrations?
  2. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I don't see why not.
    I put 1/4" rubber under all my mounting points to stop vibration and squeek.
    <a target="_blank" href=http://communities.msn.com/Ryans1972Blazer/picsofryansblazer.msnw?action=ShowPhoto&amp;PhotoID=95>http://communities.msn.com/Ryans1972Blazer/picsofryansblazer.msnw?action=ShowPhoto&amp;PhotoID=95</a>
  3. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    It wouldn't exactly be safe in a rollover because it'd allow a lot of shear movement and make it a lot easier to break the bolts. This is why they tell you not to bolt the bar down on top of carpet or insulation. Also remember that if you have the bolts pretty snug on the foot, they're going to be transmitting those vibrations and noises right from the floor to the foot anyhow.
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Hmmmmmmm.
    I've been meaning to re-do my whole rollcage setup, and tie it into the frame. Someday I get around to that, after I replace the body mounts.
    What steve chin says makes a lot of sense. Makes me want to re-do that the sooner the better now.
