roll bar or roll cage
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tmaxxer9, Mar 3, 2003.
  1. tmaxxer9
    tmaxxer9 1/2 ton status
    Feb 12, 2003
    195
    Minnesota
    Ok, i have a 75 k5 blazer and i was wondering if it would be better to put in a roll cage or a roll bar. Now it does have the stock one in it, but I want to put in something in the back to help protect my friends and family from a roll over when i take them out wheeling. I mean i ain't planning to roll it, but you just never know. you experts know how us teenagers drive. better safe then sorry. So what would be easier to install a cage or bar?? Just keep in mind that it will have to work with the top as well.
  2. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    A cage would be better if you want it to actually hold its shape in a rollover. If you can't afford one (IMO we can't afford NOT to have a cage /forums/images/graemlins/blush.gif) another rollbar would be better than nothing eh /forums/images/graemlins/tongue.gif? Check out: www.echobit.com/cgi-bin/site/products.cgi?product=1 his prices are the best I've seen and these cages probably fit our trucks better than any other companies kits being that these are built by a /forums/images/graemlins/k5.gif owner! The one pictured will not fit your '75, but he can make one that will. /forums/images/graemlins/thumb.gif
  3. tmaxxer9
    Feb 12, 2003
    195
    Minnesota
    what would be the best way to insatll it drill holes through the floor and weld it to the frame or bolt it to the floor??
  4. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Actually that one pictured will fit his 75. That is the one that is in my 74 right now. It's mainly floor differences between the years. A cut here, a cut there and whalla.
    I'm got some semi-installed pics of the cage HERE
    Hope this helps.
  5. tmaxxer9
    Feb 12, 2003
    195
    Minnesota
    now does that one go all the way into the cab, because i don't want that. all i want is something to help keep the @$$ end off the ground if i should happen to roll it. maybe i will just build a bar in stead. but does it get bolted to the floor or welded to the frame?
  6. Waxer
    1,857
    Long Beach, CA.
    It can either be welded to the floor, or bolted. The choice is really up to the owner.
    Yes it goes all the way up to the windshield and dash. It fully protects the driver, and all passengers.
  7. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    If you have a '75 you need some protection up front also. Get a full cage and bolt it in...no need to go to the frame for average wheelin'.
  8. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    It's too bad you live so far away. It sounds like your after the set of bars we removed from Waxers truck to install the cage. They are sitting here in my garage looking for a home.
  9. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    If you where ever to roll over you will want the front roll bars as well just to keep the winsheild (sp) off of you cuase it will fold in on you.
    I should put up a pic of denver75k5's Blazer when he laid over his truck when he did it his truck hit a tree and it folded the winshield frame on to him. He was very lucky the it wasn't worse than what it was.
    Eric
  10. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    do you want to be on your way rolling down a hill think to yourself as the world goes into washing machine mode "damn, i wish i had coughed up the extra coin to get a cage instead of a bar?"
    I didn't so I went cage.
  11. tmaxxer9
    Feb 12, 2003
    195
    Minnesota
    Now if you knew the 75, then you would know that it already has a bar right behind the 2 front seats. so there for elimanating the need for a cage. if my calculations are corect, if i had a bar exactly the same size, but only in the rear of the truck and rolled it to the point that it stayed upside down, then the windshield frame would not collapse all that much.
  12. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    The problem is that they don't balance flat when they hit that bar, they fall to the weight of the engine and collaps the front clip. If you fall on flat ground, you'll probably be all right.. its the boulder you roll over that will get you.
  13. tmaxxer9
    Feb 12, 2003
    195
    Minnesota
    this is true i never thought of that. boy am i an idiot. feel free to call me an idiot for a few days.
  14. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I often think so hard about my trucks design and how to impove it that its easy to overlook the obvious when tackling a complex problem. I use this board as a level check all the time, specificly so people can double check my thought process and get me back on track so I'm far from being able to call anyone stupid. I'm just happy to give it back once in a while! /forums/images/graemlins/grin.gif
    Most people really don't need a cage for the amount of wheeling they do and the stock roll bar is more than enough, some people hardly ever put their trucks in 4wd. I chose a cage because I'm the guy out there looking for trouble to crawl into (or onto) and may have my family in there to boot.
  15. tmaxxer9
    Feb 12, 2003
    195
    Minnesota
    yea the more i think of it, a cage might not be all that bad of an idea. i just don't like the way it looks going down the road. but oh well. whatis the best material to make one out of.
  16. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    This is the EXACT reason I'll be getting a cage from Mike- as most of you know- my truck doesnt go off-road- so the need for a cage for me- is protection of the little angel's heads that sit in the back seat. If for some unforseen reason my truck shall end up going over- I know for certain that they will be protected- I have read/searched for information on this board and on other sites- to know that a full cage is the way to go. I've also researched the other manufacturer options- and found the "customer service" I've already received from Mike has been 1 of the deciding factors in going with his cage. There are some things in my life I can't replace...so spending the $$ on the cage will be MORE than worth it.
    Brandy
  17. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    .120 Wall mild steel tubing is great for cages /forums/images/graemlins/thumb.gif
  18. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Thats a very debatable subject. No less than 1.5" 120 wall but everything above that adds a lot of weight with a full cage and can make an already lifted truck too top heavy. You'll have to balance out how much coverage you want with how much weight your willing to gain (or cut off the truck to make up the difference). A loaded blazer with nothing removed (including the top), 6" soft suspension lift, 1" body lift, full tank of gas, trail gear and 5 passengers on 38" tires at the stock wheel offset with a 2.5" thick 12 point cage would have a hard time keeping the wheels down on off camber climbs. The same truck reduced to 4" of suspension lift, no body lift and 33's would do well and could go much faster on the same hill. I run 38's with 4" of lift, 57" rear springs on a shackle flip with a 7 point 1.5" cage and I can feel it when I'm loaded and off camber! Drop the top and doors and its much better. It's a trade-off.
  19. yotapunk
    yotapunk Registered Member
    Jan 3, 2003
    23
    southern CA
    I know that in SCORE and MDR and other desert racing sanctioning bodies that for a full size truck in general you need 1 3/4" tubing no less then .120 wall.
    Just thought I would throw that into this conversation. On my race truck I use 1.5" .120 wall chrommoly.
