Roll Bar Pads&Covers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by malachi, Jun 13, 2001.
  1. malachi
    malachi Registered Member
    Feb 5, 2001
    18
    Sherman Oaks, CA
    Anyone know where I can get roll bar pads & covers for my 75 Blazer?
  2. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Try Smittybilt, they have some Zipper covers and also Velcro covers that go over their padding. If you can get me a part number, I will look up the price that I can get it to you for. Let me know if you find out!
    Keith
  3. ChrisM72beast
    ChrisM72beast 1/2 ton status
    May 29, 2001
    214
    Granada Hills CA.
    I tried Smittybilt's website and I found nothing. Would it only be in a catalog or did I miss it completely?
  4. Eagle
    Eagle Registered Member
    72
    Suprise, AZ
    Go to Wal-Mart and buy yourself a Pool Noodle. Buy the kind that has the hollow center. Then you can get any kind of cover you want. Cheap and very easy.
    There is a VERY fine line between hobby and mental illness
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Summit has them, http://www.jegs.com but I've heard that the customer service is better at Summit
    Murphy's Laws on Life :
    "The longer you wait in line, the greater the liklihood that you are standing in the wrong line." [​IMG]
  6. Ressurection
    Ressurection 1/2 ton status
    May 9, 2000
    360
    Prairie du Sac, Wisconsin
    I went to the local plumbing supplies wholesaler, gave them the diameter of my rollbar and they had a perfect diameter black foam pipe insulation, cool thing is it has adhesive on the slit edges. You peel a plastic strip off each, and close them together, and even with the top off, in high heat at 60mph they stay on! I am looking for a cover, tho and will check out the catalogs for that velcro'd one.
    You can't beat going Topless!
  7. kpanza
    Dec 8, 2000
    1,579
    The Smittybilt part number for the 2" rollbar padding shows to be RP200...it doesn't (of course) show what length each unit is...my guess is it must be a couple of feet at least, since my JOBBER COST on that is $9.27!! If I can find out, I will post it on here, otherwise if anyone finds out, I can have it ordered and shipped out to you. Of course, if you could get it at your local parts store (and have them pay the shipping), you could probably save some money...if not, let me know and I will see what we can do!
    Keith
    PS- the covers come in all different sorts of lengths, try to let me know which ones you would be interested in, I will check them out... Velcro - 19", 27, 36, 38, 39, 41" Zipper - 19, 21 30, 32, 34, 36, 38, 44, 48, 51, 57, and 61"
  8. Grim-Reaper
    7,385
    Atlanta
    Understand this. Pipe insulation is not really a roll bar pad. Roll bar pad is made with a high density foam. there is some pipe insulation made of the same stuff and the pool stuff is fairly close also. What you don't want is that black foam rubber stuff. The real dea SFI stuff that Jegs and summit sells is the good stuff but it is expensive!
    It's not my damn planet monkey boy!
    Grim-Reaper
  9. malachi
    Feb 5, 2001
    18
    Sherman Oaks, CA
    Talked to the people at smittybuilt the 61" cover is the longest they have. My stock roll bar is 96". I guess I could put two together but I was hoping to just have one piece. Maybee I'll just have to make it myself
