roll bar
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by swank, Apr 19, 2002.
  1. swank
    swank Newbie
    Apr 19, 2002
    ohio
    looking for a roll bar for my 72 blazer
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    your best bet would be to find a local fabracator to make one for you. Try the yellow pages for race shops or welding shops and start callin around. That worked for me....
  3. WD Steeves
    WD Steeves Registered Member
    Nov 9, 2001
    16
    B.C.CANADA
    I got a roll bar from a short box Chev,arced the mountpads off,cut the tubes down 3" I believe, ( it has been awhile since I did it) in a cut off saw,rewelded the mounts on, had it powder coated flat black,positioned it in the Blazer,marked the holes in the mounts and drilled and bolted it down,On the bolt that holds the uprights to the top cross over tube I mounted the hanger for new shoulder harness seat belts from Mothertruckers.The short portion of the belts mounted to the existing holes,but I had to use a couple pieces of aluminium angle.It turned out really well,I will post some pic,s of the Blazer soon (frame off restoration/customize ) Regards
  4. SilverJim
    SilverJim 1/2 ton status
    Sep 23, 2000
    105
    Evergreen
    www.swracecars.com
    these guys have some good looking cages for what seems to be good prices
  5. Bill4rest
    Bill4rest 1/2 ton status
    Jan 12, 2002
    103
    Vista CA. (so cal)
    As soon as I get a 2" die for my JD2 bender I'll be putting in a roll bar or a full cage (have not decided):)
  6. bitchin4x4
    bitchin4x4 1/2 ton status
    Jun 26, 2001
    106
    Denver, CO
    Re: roll bar - sold *DELETED*
    Post deleted by bitchin4x4
  7. ED70K5
    ED70K5 1/2 ton status
    Apr 28, 2000
    179
    Texas, USA
    I just dug up an old article that I scanned from a 4x4 Power Magazine, which was about Roll bar Tech. I beleive the install was the Smittybuilt Rollcage and it was installed on a first gen K5 too! Let me know if you want a copy and I will mail it to you.
  8. Bill4rest
    Jan 12, 2002
    103
    Vista CA. (so cal)
    That cage seems interesting, do you have any other pics of it?
  9. Hawkeye
    Hawkeye Registered Member
    Mar 14, 2002
    5
    Oklahoma, United States, North America, Earth, Sol
    i've got a decent used roll cage from my 72 K/5 that is just sittin in my back yard. if you are interested, let me know, and i'll try to get pictures of it for you. make an offer and it's yours.
  10. jeffer
    jeffer 1/2 ton status
    Nov 6, 2000
    113
    Loveland, Colorado
    bitchin4x4,
    Don't know if you got my PM. I didn't see anyone else pipe in, I'm interested in your smittybuilt cage. I live north of Denver. Let me know.
    Jeff.
  11. bitchin4x4
    Jun 26, 2001
    106
    Denver, CO
    I had the guys from around here in Denver, CO do it. the name is "wicked offroad works" if anyone wants the info let me know.
    l8
    sean
  12. ED70K5
    Apr 28, 2000
    179
    Texas, USA
    Went to your website and looked around. Do you have close-up pics of your cage?? I would sure like to see how your spare is mounted to the cage. That is one ****ing sweet RIG!! I'm sure i'm not the only one that wants to see some close ups, so stopping teasing us!!! LOL
  13. NuBombs72K5
    NuBombs72K5 1/2 ton status
    Jan 21, 2001
    145
    Georgia
    Is 2'' pipe the size most use or 3''. I just found out my father-in-law has a pipe bender and I want to make a roll bar that is similar to factory (4 point) and fits under a new fasttrack as well as the hard top. Does anyone have measurements or anything to point me in the right direction.
  14. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Do some searching...someone posted some interior dimensions a long time back.
  15. Robin
    Robin 1/2 ton status
    Oct 30, 2001
    184
    Georgetown, Texas
  16. NuBombs72K5
    Jan 21, 2001
    145
    Georgia
    Thanks Robin, but I was actually looking for more like a stock roll bar and not so much of a cage. My blazer is more of a daily driver than a rock climber. Thanks though.
  17. bitchin4x4
    Jun 26, 2001
    106
    Denver, CO
    got the neighbors digi camera and working on some pics. should have some up over the weekend
    l8
    sean
