Roll Bars
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Ptangler, Mar 22, 2001.
  1. Ptangler
    Ptangler Registered Member
    Mar 22, 2001
    9
    I just bought a 72 Jimmy. It has no roll bar. I have not picked up the rubber floor mat to see if there was once one mounted. I was wondering if they where stock or an option. Also where can I find one. The fiberglass top is in good shape but I dont think it will support the weight of the truck.
  2. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    I'm not sure if the roll bar was an option or standard. I know that factory bars can be hard to find. Smittybilt makes an aftermarket bar for the Blazer that is passable for light street duty, but it'd never pass an SCCA inspection.
  3. Roostr84
    Roostr84 1/2 ton status
    Aug 19, 2000
    451
    NJ
    I believe the bars were an option. Ditto on the smittybilt. you might want to look at getting one fabbed locally,
  4. Ptangler
    Mar 22, 2001
    9
    Do you know where I can get the specs of the factory bar?
  5. Steve_Chin
    Mar 6, 2001
    1,126
    There were at least two different factory roll bars. One of them is a goofy dual hoop arrangement (that's what's in my Blazer), and the other was a more traditional design. Neither was really very worhty of being called a "roll bar." I believe that Bill O'Grady at Vintage Chevy has at least one factory bar of the single hoop type.
  6. NuBombs72K5
    NuBombs72K5 1/2 ton status
    Jan 21, 2001
    145
    Georgia
    I would like to see the specs too. If anyone has had one made, how much did it cost. I know it will vary, but just to get an idea.
  7. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    This cage was made by a dude I found in the Yellow pages under Pipe Bending. He is in SanJose Cal. SanJose PipeBending is the name of the place. He only makes cages on the side. I took a Friday off work and helped him make it by holding the pieces and telling him what I wanted. This cage is of the 'Halo' style. OH ya and he charge me 300 bucks back in 95. If want more pics go here:
    http://www.burt4x4.coloradok5.com
  8. NuBombs72K5
    Jan 21, 2001
    145
    Georgia
    Thanks Burt. That looks like what i want. Is it welded to the body or through to the frame? I'll have to look for someone here it atlanta who can do as well. Nice blazer. Thanks again!
  9. Burt4x4
    6,854
    It is welded to mounting plates then bolted to the floor. The center hoop that goes right behind the seats to the floor is bolted to the floor's cross member under the body so that is the strongest mounting. I plan on changing it around to an 8 point and more gusset work.
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
