roll cage construction
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CAROLINAK5, Dec 16, 2001.
  1. CAROLINAK5
    CAROLINAK5 1/2 ton status
    Aug 2, 2001
    242
    lexington, north carolina
    i have no clue!!!!!!
    what is the choice material for a roll cage? can i purchase a bender to work the material (cheap)? yes, i have access to a welder.
    when all else fails..............HIDE!!!!!!!!!!!!!!!!![​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/albun32>http://coloradok5.com/gallery/albun32</a>
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Usually 2", .120" wall HREW tube is what works best. DOM is stronger but not necassary unless your going to be rolling over very fast. If this "cheap" bender you found is the one in the back of Harbor Freight for $100, it wont work. Thats a pipe bender which will kink and weaken your tube since pipe and tube are not the same. JD2 makes a nice tube bender, its about $250 plus dies.
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Full cage go wiyh 2" .120 wall. Thats what I did. And like its was said above you need a reall tube bender, not a pipe bender.
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
