Roll Cage Questions
Discussion in 'The Garage' started by FMJ, Feb 19, 2005.
  1. FMJ
    FMJ Registered Member
    Dec 29, 2004
    94
    Duluth, MN
    I'm going to put a roll cage in place of the bed on my truck, but i need to clear up a few things before i start. First, what thickness tube should I use? I was thinking maybe 2" 3/16, or should i use 1/8? Also, as far as mounting it goes, I was planning on just using like an L shaped mount that would sit over the frame with some thick rubber between it and the frame and then just bolt it in with 3 bolts. What do you guys think?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    2" .120 (1/8") wall is what is generally used for fullsize truck rollcages. As long as the design is sound it is more then strong enough to handle the job. The thick rubber mounts are also a good idea.
    Harley
  3. FMJ
    Dec 29, 2004
    94
    Duluth, MN
    I'll probably go overkill on the design.
  4. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    If you are going to go overkill on anything the cage is prob the best place to do it. I used 2" .120 for my cage.
