roll cage seal
Discussion in 'OffRoad Design' started by crewcab, Apr 11, 2002.
  1. crewcab
    crewcab 1/2 ton status
    Oct 14, 2000
    396
    what did you use to seal your rolll cage were it goes through the floor?????
  2. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    I didnt seal it. sh!t, if the water wants to come in let it. it'll find a way. i just bolted it in. u dont notice a difference
    NITRO
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    My base plates have tabs welded to them that run through slots in the floor. the bushing assembly bolts to the tabs and is mounted to the various frame mounts. I just siliconed the base plates and it's pretty tight. I do have several tubes that go straight through and a couple of them are just right at the size of the hole and have a bead around them, that's all. With a rigid chassis they don't move much. The other pair has a duct tape boot around them to keep it sealed up. We've used deck-tite boots on a couple of penetrations also. They're a weather tight boot for sealing pipes coming through roofs on buildings. Maybe a home depot as a source? They're the gray boots around the cage bars in the engine compartment. You might be able to see them in some of the pics on our site.
