Roll Cage Shop In Sacramento?
Discussion in 'Pacific Region' started by NorCalKid, Oct 16, 2006.
  1. NorCalKid
    NorCalKid 1/2 ton status Premium Member
    May 6, 2005
    1,604
    7
    Davis California
    Anyone know of a shop near sacramento that will weld in a smittybilt cage and add and connect a rear hoop?
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Is Chico too far for you?
  3. NorCalKid
    May 6, 2005
    1,604
    7
    Davis California
    I was hoping to go some where closer but if I cant find anything Its not that far.
  4. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    OK, try Mike at Bent and Twisted. (530)342-3003
    He did the cage on my Blazer - he will know who if you tell him Dave with the Black Blazer.... :D
  5. NorCalKid
    May 6, 2005
    1,604
    7
    Davis California
    Thanks. That looks like a pretty nice cage. I will look into bent and twisted.
  6. NorCalKid
    May 6, 2005
    1,604
    7
    Davis California
    Quick Questions:
    Is it tied into the frame or body mounts or just on the floor? And how much did it cost you?
  7. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    It is tied into the frame via the nerf bars only.
    I could not begin to put a price on it as it was part of a BIG upgrade. Not trying to be cute, just it was all bundled together. Mike will give you a good quote though.
  8. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    You make any progress?
  9. NorCalKid
    May 6, 2005
    1,604
    7
    Davis California
    I emailed bent and twisted but they havent responded. I will probably give them a call though. I found a shop in sac who said they could make one and tie it to the frame for about 11 to 12 hundred. I cant remember the name off the top of my head but I think it had somthing to do with custom trucks. I liked how bent and twisted did your cage though so if they are in the same price range I will probably head up there.
  10. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Cool, give them a call. Email did not work well for me with them. Mike is always in the shop by 8:30 - he can chat better in the AM ;)
  11. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    There is also Phil aka silly fab in sac. I can get you his number if needed.
  12. NorCalKid
    May 6, 2005
    1,604
    7
    Davis California
    If I can get that number it would be great. I am having u-joint angle problems due to bent spring pearches, so the cage might be put off untill after I fix that. Sence the pearches, gears, and brakes are bad I am thinking of just swaping in 3/4 tons if i can find some cheep.
