Roll cage tubing???
Discussion in 'The Garage' started by outlaw612, Feb 2, 2003.
  1. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    What size is standard? 1.5 or 1.75" ? What wall size?
  2. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    S&W Racecar's cage is made from 1 5/8" x .134" mild steel.
  3. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    Most people build cages from 1.75" or 2" OD tube with a .120" wall thickness. 1.5" is a bit too small for a heavy rig IMHO.
  4. outlaw612
    Feb 11, 2001
    2,342
    Thanks guys, I was thinking 1.75", but just wanted to be sure.
  5. Longhorn4x4
    Longhorn4x4 Registered Member
    Oct 19, 2002
    67
    Tennessee
    For most applications, the best tubing is mild steel,
    1 5/8" diameter, .120 wall DOM, mil spec. DOM stands for Drawn Over Mandrel, which means the tubing is seamless. A welded seam significantly weakens tubing. ERW tubing is seamed, ERW stand for Extruded Rolled and Welded. Also mil spec DOM is certified for content and the diameter and thickness are held to extrmemely close tolerances.
    Most often the 1 3/4" wall tubing sold by the majority of vendors is ERW, and it is .137" wall thickness. The reason it is that thick is because it is not mil spec certified, and the content and wall thickness are not as closely controlled.
