Roll Cage Welded to wind. frame?Pics???
Discussion in 'The Garage' started by atlantak-5er, Dec 2, 2003.
  1. atlantak-5er
    atlantak-5er 1/2 ton status
    Aug 20, 2003
    225
    Atlanta, GA
    I needs some pics of where I can weld a roll cage to the Windshield frame on my '75. What should I use, plates, or tube, or pipe?
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Are you talking about a style like a stock TJ where the bars stop at the wndshield frame?
  3. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I'm not sure that I like the idea... a cage without the down bars directly over the driver compartment doesn't sound worth the savings in tube, space, time or anything else. Just my .02.
    -Dan
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Its been discussed before I believe, jeeps have that part of the body designed to be structurally strong so its ok to put a cage to there(I'm talking bottom of windshield around the dash) but on a K5 its not designed to same, go with full down bars to the floor, a cage is no place to skimp or cut corners.
  5. atlantak-5er
    Aug 20, 2003
    225
    Atlanta, GA
    No, thats not what I am talking about. Sorry I was not clearer. I have a roll cage (dragster style from S&w racecars already installed in my truck. It has full down tubes, etc. I just want to weld my windshield frame to the rollcage to hold the windshield frame in place. It flexes and my doors dont close right when not parked level. I belive my rocker boxes are gone (rusted out). Kind of like what that guy said about a TJ's. Where shoud I attach it and how? /forums/images/graemlins/k5.gif
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The windshield frame isn't strong enough to prevent the whole body from flexing. If you weld the cage to the windshield frame the most likely result will be a twisted windshield frame and/or a broken windshield. /forums/images/graemlins/eek.gif You're gonna need to do something to beef up the rocker box area. /forums/images/graemlins/frown.gif One thing that may help minimize the body flex is to install kicker bars between the front and rear downtubes of the cage. /forums/images/graemlins/cool.gif (Just make sure that the body is straight when you weld 'em in.) /forums/images/graemlins/wink.gif
  7. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Somebody on this board has done this with good results. He did have good rockers and had the sag issue. He welded in some square tubeing between the cage and the top. I plan on something like this.
    I dont think you will tweak anything out. Thats what the windshield pillers were doing with the full top on anyway.
  8. Grim-Reaper
    7,385
    Atlanta
    YeildToMe has done it and it worked out good. I thing Muddin did it on her rig as well. Yeaild just made a fill peice between to headach bar and the windsheild header. I plan to redo my cage one day. I'm going to make tgusset plates like you see on a WRX rallye car with the dimpled holes up the pillars and then a couple 4 inch wide tie ins between where the plates for the hardtop go. Now when I redo the cage it will be a lot closer to the windsheild frame. I aill also tie it into the kick pannels.
  9. atlantak-5er
    Aug 20, 2003
    225
    Atlanta, GA
    Thanks Grim, I hope you are recoveing well. I am going to try to weld some square tubing to the frame and see what happens. Let me know next time you guys go trail riding. I just was at rich mtn. last weekend.
