Roll cage
Discussion in 'OffRoad Design' started by Truckdweld, Feb 26, 2001.
  1. Truckdweld
    Truckdweld Registered Member
    Jan 26, 2001
    26
    Sonoma county, CA
    Stephen, I want to put a roll cage in my full size chevy truck. I am going to use 2" tubing. Do you think that 2"x1/4" would be over kill. Should 2x1/8 be strong enough. Thanks Ryan
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I was just perusing my SCORE rulebook from a couple of years ago yesterday and for vehicles over 5000 lbs, 2x.120 tubing is required for rollcages. Seems like a good choice.
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You got any pics of your 'cage, Stephen???
    Murphy's Laws on Life :
    "Leftover nuts never match leftover bolts." [​IMG]
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    2" x .120 wall would be fine. K5's really hold up pretty well in a roll over due to the beefy structure over the front seats, so your priorities should be bracing up the windshield frame area, and protecting the passengers. I used DOM tubing for mine, but even welded seam would do the trick. In a full removeable top, you obviously have a bit more to worry about.
    Also keep in mind that a cage can go a long ways toward stiffening the frame, in addition to protecting the passengers. If you can take it to the frame, do it. I had a lot of frame flex in mine before I caged it, now it's pretty stiff.
    I don't have any digital pics of it, so I'll see if I can snap a few sometime. The back seat's out of it, so it'll show off a little better at this point.
    Making the world better, one truck at a time.
    SW-ORD
