Roll Cage
Discussion in 'The Garage' started by slyguy_22, Dec 21, 2004.
  1. slyguy_22
    slyguy_22 1/2 ton status GMOTM Winner
    Dec 13, 2004
    789
    Lancaster, PA
    Anyone know of any companies that make prefab roll cage kits for our blazers
    (79/89 K5)
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    search buttonn is your friend. s&w , & smitty built
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Smittybuilt uses crap metal for there cages. I would avoid them.
    Harley
  4. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    From what I have seen available, you either settle with a crappy smitty bilt which might help out the front passengers in a rollover, or get one custom built if you want a real full cage.
  5. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    The weld in kit for the front from smittybuilt is DOM tubing
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    It is HREW. I have one in my back yard. The steel they use is crap itself. It is a pain to weld. I have a low amp machine and was not able to hold a bead on the junk tubing, it would just blow through. I have hand built several cages and bumpers and the fit was perfect, the metal was cleaned, it just didn't want to work. I was one pissed off person because I take a lot of pride in my work and this is not how I want my work to look. I used the front half of smitty and a custom rear half I did myself, the rear half was fine. I would never reccomend that cage.
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Thats weird because on Micah's smitty built cage the front half was DOM or at least it is some weird HREW with no weld seam:confused:
  8. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    I thought the same the first time I saw one. Let it get a little surface rust and the seam will jump out. DOM doesn't show its seam outside even rusted. I was more concerned with the actual grade of steel smittybuilt is using. It was very wierd to weld. I have migged mild, DOM, pipe, galvy, even chromo, but this crap was just wierd to weld. I won't do another one that is for sure.
  9. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
  10. skelly1
    Sep 2, 2002
    554
    San Diego, CA
  11. ugly
    ugly 1/2 ton status
    Aug 8, 2004
    157
    Denver
    nice link Scott. I have a Rock Ware cage that has custom add-ons. I like it; seams stout.
