roll cage
Discussion in 'The Garage' started by 74beater, Sep 22, 2003.
  1. 74beater
    74beater 1/2 ton status
    Sep 20, 2002
    242
    ELGIN ,TX
    i'm about to buy a jegs cage for my jimmy...how should i attach it to the frame..i was thinking about some 2x2 sq tubing off of the frame...please advise
  2. earl87gta
    earl87gta 1/2 ton status
    Apr 6, 2003
    551
    Chuckey TN
    I would check out the speedway cage as well before you buy the Jegs cage I think they are a little cheaper and their cage is desined to bend down and weld to the out side of the frame.
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">I didnt know Jeg's made a Blazer cage /forums/images/graemlins/thinking.gif. Check the tube size before you order, dont use anything smaller than 2" x .120"
  4. 74beater
    Sep 20, 2002
    242
    ELGIN ,TX
    JEGS CAGES ARE 1.75..IT'S THE CAGE FOR THE P/U
  5. 74beater
    Sep 20, 2002
    242
    ELGIN ,TX
    WHAT THE WEB SITE FOR SPEEDWAY...
  6. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    all i can say is S@W, S@W, S@W !!!!
    all i ever used in the race cars. I've got one in my 73 blazer.
  7. 74beater
    Sep 20, 2002
    242
    ELGIN ,TX
    thanks brother
  8. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    check what material the tubing is hrew or DOM. Most people say DOM is overkill, but not when it's my life.
    1.75"x1.25" DOM is fine... also look at the cage design.
  9. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    Why is DOM better than regular tubing? There both made of the same steel, but one has a seam, and one dosn't.
  10. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,608
    558
    Wasilla AK,
    they both have a seem just on D0M you can see it from the outside
  11. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    dont quote me, cause i dont really know what im talkin about, but i would guess that the tubing with the seam would be weaker than the solid tubing (DOM?), as the seam would create a weak point? correct me if i'm wrong... /forums/images/graemlins/ears.gif
  12. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    They both aren't made from the same steel. HREW tubing is made from 1010 steel, while DOM is made from 1020 (a stronger steel), the process in which its made also adds to the strength)
  13. earl87gta
    Apr 6, 2003
    551
    Chuckey TN
    http://speedwaymotors.com Their DN is 402-323-3200 thier complete cage 16 point is $449 but you probly wouldnt want all of that it has the door cage kit and the engine compartment cit with it for that price. I was going to see how much more it would be for them to leave the top rails longer so I could make a famly cage out of it I wish I had a scanner so I could scan the pic of the cage for you.
    Earl
  14. earl87gta
    Apr 6, 2003
    551
    Chuckey TN
    I almost for got thier cage goes threw the cag and ties in to the frame under the truck it would be a perfict place to weld in a set of rock sliders.
    Earl
  15. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Not to be too technical about it, but the grade of steel isn't necessarily tied to the DOM vs. HREW. DOM vs. HREW is strictly the process. DOM is HREW with more work applied. But, usually DOM is found in better grades of steel such as 1020 or 1028 while HREW is most often found in 1010 or similar depending on local demands. Though it would be entirely possible to have 1010 DOM and 1020 HREW...
  16. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Thanks for clearing that up, Professor! /forums/images/graemlins/tongue.gif /forums/images/graemlins/wink.gif
  17. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Both are seamed tube though. DOM is built to tighter dimensional tolerances than HREW. Wall thickness does not vary as much...we're talking in thousanth's of an inch though.
    HREW is perfectly fine for roll cage material...unless you're doing 140mph in the desert or you have an unusually large wallet./forums/images/graemlins/smile.gif
    I have more concerns about weld quality and design than whether it's DOM or HREW.
    Rene
  18. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    Im 2nd that! It doesn't matter type of steel if it isn't welded right!!
  19. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    I can't see the .1 percent more carbon that 1020 has over 1010 would make that much difference anyways.
    I found out today how DOM was made. A rod is peirced through the center with a pointed shaft held by 4 to 6 sharpend spokes. The red hot rod is pushed over the pointed shaft and cut by the spokes into 4 or more peices. It is then fused back together while still glowing hot. The tube is then allowed to cool, then drawn over a long (20+ foot) manderel to give it uniform thickness. The last process also puts some "cold roll" characteristics in the steel such as more surface tension.
    Just sharing what I learned. Kind of interesting.
    Anyways, I don't see the need to use DOM for a cage unless I had extra money laying around with nothing to spend it on (Hardly the case).
  20. 74beater
    Sep 20, 2002
    242
    ELGIN ,TX
    YALL ROCK...THANKS FOR EVERYTHING GUYS...
    ALL HAIL THE ALMIGHTY SAWZALL
