Roll pin question on Dana 60 carrier
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tomseviltwin, Aug 21, 2002.
  1. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    I'm trying to drive out roll pin so I can remove cross pin to install my new Lockright. Using hammer and drift, but the damn thing won't budge. Any ideas? /forums/images/icons/confused.gif /forums/images/icons/crazy.gif /forums/images/icons/frown.gif
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Man, that's a tough call, this close to BB02. I wonder if the cross shaft is twisted in the bore, and the roll pin is busted off inside?? My first thought was to hit it harder, but on second thought......Can you move the cross pin at all in any direction?
  3. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I had the EXACT SAME situation (minus the ript to Moab around the corner /forums/images/icons/tongue.gif ) i too was worried about hitting it harder. but what i eventually did was hit the crap outta the crosspin and eventually the roll pin broke---went to Lowes (or any hardrawe store and bought some moreroll pins the same size.----may not be the best method but it worked for me
  4. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Try using a smaller punch. The hole that the roll pin is in necks down on the inside so that only a punch the same or smaller diameter as the roll pin will fit.
  5. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    Thanks guys,
    It doesn't look like anything is twisted in there. It's just stuck!!! I do see where it necks down.
    I just sprayed it with pb blaster and will try beating it harder with a smaller punch in the morning. Unfortunately, my plans for installing all this stuff this week went out the window. I'm still going to Moab this weekend, but I'll still be in 3/4 ton unlifted gear. Besides, 3/4 ton unlifted gear isn't so bad. It's still gonna be fun.
