rollcage mount question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, Aug 11, 2001.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    I recently had a rollcage installed into my blazer because it is a full convertible. it was welded into the floor boards up front, the section behind the front row of seats its kind of a ledge, and finally the back end had plates welded into the wheel wells. My dad finally saw the cage completed and was not satisfied because he claimed that it wouldnt work because its not welded onto the frame. What is yalls opinion on this and is the cage strong enough to protect the driver and passenger in case of a rollover.
    for pics http://photos.yahoo.com/gmc2500sub
    phill
  2. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    If Its Welded To The Floor Pan It Will Tear Away In A Accident.
    It Needs To Be Attached To The Frame To Work.
    A Big Hammer Can Fix Anything ..
  3. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    <a target="_blank" href=http://photos.yahoo.com/gmc2500sub>http://photos.yahoo.com/gmc2500sub</a>
    Real four wheelers don't need tools to remove body panels, paint, tail lights..etc.
    P.S. Ask me why it is called "BODY SNATCHER"
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Make outriggers bolted to the frame that extent to under where your cage was welded. The best way is to weld plates to the bottom of the cage and then bolt the plates through the floor to the outrigger. </font color=blue>
  5. aaaaggh
    aaaaggh 1/2 ton status
    May 4, 2001
    161
    birmingham alabama cause there no ham like birming
    if it goes to the floor with different sized sandwich plates then it will be fine for offroading. if you plan on it working at a highway speed rollover then it needs to go to the frame.
    friends romans countrymen, lend me some parts
  6. Grim-Reaper
    7,385
    Atlanta
    Well if the front legs are just inside the kick pannel then your dirrectly over the front cab suport. Fairly sturdy point (except for the rust). The middle tube if your using the factory location is over a heavy body suport also. The third legs if to the top of the fender wells is worth less. They will fold like a beer can. Should have run them all the way back to the corners and but a good backing plate in so you can take advantage of the tail pan for suport. For off road that is not to bad a set up. I made a custom Tailpan for mine out of 7 inch wide C Channel. My floor was replaced due to rust and I made a sub frame that ties into the 1st and 2nd cab suport and my cage bolt to it. Still not as good as a true to the frame but better than to just the sheet metal. Some pictures on my site, Link in sig. I haven't got the pictures of my cage up yet.
    It's not my damn planet monkey boy!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    Grim-Reaper
  7. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    I have mine welded in the same places except for the rear fender wells....mine go to the corners.I'd have to agree with Grim.....not my frst choice on the rear wells, but the others should be fine. Attaching a cage directly to the frame causes LOTS of noise and vibration to be transmitted to the cab....to the frame would be best for all out safety, but not required for slower stuff, besides it's gotta be better than the "no cage" you had before.
    Michael[​IMG]
    <a target="_blank" href=http://www.jmartin.net/parker/goose.htm>www.jmartin.net/parker/goose.htm</a>
