rolled my blazer in Moab...now electrical problems?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by juanblzer, Aug 27, 2002.
  1. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    drove my blazer for at least 4 hours total time after my brief "lay-over". THen I had a brainfart and left my lights on for about 4 hours while the truck was off. I jumped the optima battery and it would not hold a charge. Now the starter won't even click.
    I repaced the cap and coil (I had a spare cap with coil in it)
    I replaced the ignition module under the cap
    I replaced the rotor
    I am completely stumped. I did find a fusible link that had burned right on the firewall above the distributor, near the brake booster.
    Someone please help, my blazers my only means of transportation. I am a newbie to mechanics so bear with me.
    Thanks in advance.
    juan
  2. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    possibly crack the battery? (inside) Have you tried a different battery yet?
    John
  3. CK5
    May 19, 1999
    21,624
    702
    CO
    Where did you roll it?
  4. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    it was an optima mounted under the passenger seat. I think that leaving the lights on for 4hrs killed the battery. Anyway I used a loaner battery from Napa and it still wont fire.
  5. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    Hell's Revenge near the trough at the base of Lion's Back. Goofing around climbing the vertical face of a rock. FWP an BadDog and Marv and Robzilla all saw it as they also climbed up the wall for a photo op. Anyway... I went farther than BadDog ... and I have the dents to prove it. Keith got some pics of the blazer on its side. It was pretty much a non-event but my adrenaline sure was firing. Now my distributor isn't though.
    juan
  6. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I would start tracing wiring. Either a connection came loose, or a wire touched a hot part, and is shorting out. I would start tracing at the starter and work my way up. Hope this helps.
    John
  7. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    check your grounds from the engine to the battery and engine to chassis. try and disconnect/connect every connector that you can get a hold of, one of them could of gotten corroded. if yo ucant disconnect/connect them wiggle them, specially the ones going into your firewall. you can always hot wire it. run a wire from the + coil to the + batt and crank it. that should keep you going for a bit longer. just remember to disconect the wire to turn it off /forums/images/icons/smile.gif
    ARQ.
  8. 83PJW
    83PJW 1/2 ton status
    Aug 18, 2002
    160
    leavenworth, ks
    pos wire from battery to starter maybe??????
  9. blazentank
    blazentank 1/2 ton status
    Apr 18, 2001
    426
    Houston, Texas
    How bad was the damage to your blazer. Also did you take pictures of the roll-over or the damage it did. if you do post the pictures please
