roller rockers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by crazylarry74, Mar 21, 2001.
  1. crazylarry74
    crazylarry74 Registered Member
    Feb 7, 2001
    66
    Colorado
    My friend has roller rockers in his 68' chevy and is parting it out because of a blown engine when the engine blows will the rockers be destroyed to and how hard are they to install?
    CrazyLarry
  2. K10
    K10 Registered Member
    Feb 18, 2001
    52
    Rexburg, Idaho
    If you are going to run roller rockers you will need pushrod guideplates on your heads.
    <A target="_blank" HREF=http://nick.rockcrawler.com>http://nick.rockcrawler.com</A>
  3. crazylarry74
    Feb 7, 2001
    66
    Colorado
    would it be worth buying them he is only selling them for $50 and they only have 500 miles on them. how much would it cost to get new pushrod guideplates?
    CRAZYLARRY
  4. dyeager535
    26,982
    191
    Yep, what he said. You'd have to pull the heads and have a machine shop pull the studs, tap the holes for screw in studs, and get pushrod guideplates. You may end up buying different pushrods as well, to get the tip to contact the valve stem corectly. Basically, if you aren't rebuilding the heads, forget it.
    The rockers SHOULDN'T have been damaged by the motor blowing up, you just need to inspect each rocker for any type of damage. FWIW, you can get cheap full roller rockers for about $130 brand new.
    Dorian
