Roller vs non roller motor
Discussion in 'The Garage' started by sled_dog, Jun 29, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Ok what are your opinions? If installed a roller motor in my 89 Burb think I would see a MPG increase? I'm thinking about going back to driving my burb, make it a little more capable a little better hauler and drive it and sell my 2wd. I have access to a stock roller 350 that I would swap my heads and intake onto and drop in the burb. Thoughts on doing this? Be worth the time you think? Figure I could port and polish heads a little bit while I am there, try and get a little more flow, maybe slightly stronger springs for when she sees upper RPMs.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    It will reduce friction, this is good. I suggest some roller rockes as well. Slight increase in MPG if you drive nice. The most improvement will be in oil temp and engine longevity /forums/images/graemlins/k5.gif
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I remembered that I need to locate the camshaft info as well. The roller motor is from a 9C1 police car and has a little more agressive camshaft than say a standard Caprice motor.
  4. dyeager535
    26,979
    I really dislike the idea of the TBI truck heads, but what heads are on that 9C1 motor? They might be better heads anyways...and should allow your TBI intake to bolt right up as well, no?
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    no they will not, at least I am pretty certain they are standard bolt pattern (older style) heads. IT has an electronic QJet on it. If the heads on it will work I will just run them, cause like you said I am sure they are better. But the only other heads I have access to are 882 factory 72cc heads and thats just not gonna cut it.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Take a really close look at the angle of the intake bolts on the Caprice engine. I've seen them with Q-jet intakes that have the inner bolts angled to mate with the heads, just like on a TBI engine. /forums/images/graemlins/eek.gif
  7. dyeager535
    26,979
    I was under the (perhaps mistaken) impression that if it's a roller block, it will have to have the vertical center intake bolt pattern? Thought those changes happened at the same time.
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    maybe you are right and I am wrong, really don't know.
  9. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    i would think the roller set up would be the way to go regardless what you run on top of it you can get a lot more cam for your buck an you don't have to spend a lot of money to build a roller set up just top it of with a set of roller rockers and i'm sure you can find a wicked combo to match /forums/images/graemlins/thumb.gif
    those 882 arn't that bad iv'e had good luck with them the cc is a little large but if you run some flattops maby shave them down it'll bring the compresson ratio up they have really good flow numbers that helps out big.
    althogh those caprice heads are probably better /forums/images/graemlins/dunno.gif i'd look into those /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
  10. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Dont knock those 882's, they are some good heads. Id say the heads on the 9C1 caprice engine are the same face pattern as the TBI intakes. I have only seen two, but they have both been the later pattern.
