Rolls around while in park
Discussion in 'The Garage' started by wheelzss500, Jun 16, 2005.
  1. wheelzss500
    wheelzss500 Registered Member
    Feb 16, 2005
    5
    Ottawa
    most of the time my park pin wont engage and the truck will roll around in park
    how do i fix this?
    thanks alot in advance
    eric
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Does your shift indicator line up properly ? Maybe linkage isn't adjusted right ?
    Put it in park at the transmission with the linkage off and see if it works .
  3. dyeager535
    26,980
    Use your ebrake.
  4. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Get a 465.
  5. wheelzss500
    Feb 16, 2005
    5
    Ottawa
    it doesn't line up with the indicator
    and yes it wil sometimes go into park properly with the shifter if i jam it up there pretty hard
    how do i go about adjusting the linkage?
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    linkage is deffinetly missadjusted.
    on the left side of the tranny, you will see some rods. on the one coming down from the column, there is a bolt. loosen the bolt, put the tranny all the way in park, then put the column all the way in park, and tighten the bolt. just make sure to block the wheels first, don;t want the truck to roll over you.
