Roof Antenna
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by taterblazer, Apr 6, 2001.
  1. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    Are the roofs of the cab double thickness or single?
  2. Grim-Reaper
    7,385
    Atlanta
    Double but it can be done just need to drill a second hole. Use a 3/8's at an angle once you make the hole through the outside to dill a hole inside. if there is not enough gap to get then base in then take a socket extension and you can dent the inner pannel to get the room. This of course is if you have a truck with a head liner.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  3. taterblazer
    Feb 2, 2001
    277
    Boise, ID
    thanks grimmy, my mount requires a big hole in the bottom layer of steel. Will it hurt to drill a 2 inch hole in the lower layer? Oly rules!
  4. Grim-Reaper
    7,385
    Atlanta
    Souldn't hurt a thing. The inner headliner will hide it. You might what to have some paint ready to dress the raw edges so condensation doesn't cause it to rust.
    Grim-Reaper
