roof laying in front yard, need pic of 73-75 doors...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by yeild2me, May 27, 2001.
  1. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    i am about to cut the doors, but i need a pic of them with the caps off to see how they are cut......thanks
    AIRBORNE!!
  2. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    hey im doing the same thing, how did the cutting go? big hole left in top of the bed rail? thx j.c.
  3. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    cutting the roof wasnt to bad...its filling the holes that sucks!! weld, weld, weld...grind, grind, grind ....trying to make it even across before i finish it with bondo. i was supposed to get pics of MTpockets doors before i left so i would know how to cut them, but i forgot...[​IMG]
    AIRBORNE!!
  4. 1990K5
    Nov 6, 2000
    460
    LITTLETON CO.
    i think the doors are pretty simple, two straight cuts then you have to 45 the top of the wing window frontwards towards the windsheild. did you mount your shoulder belts to your roll cage? how much did you get you windsheild frame stubbed and grafted for$ ? cheapest i found for quality work was $350. i would do that myself but that has to be exactly the right size. any plans for a bikini retainer yet? thx j.c.
  5. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    I can get you a pic in the morning if you still need one, it's too dark to do now. When you cut, I suggest that you cut a little higher than what you think you need and then test fit. Once you know how it looks on the truck, then you can cut or grind down to the final dimension.
  6. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    i am putting a 73-75 softop on, so i am not messing with grafting a header for a hard top. the sucky part is welding the steel to cover the gaping holes. welding sheet metal is also kicking my a$$.
    jason, if you can still get those for me, i would appreciate it!!
    1 of the top, and one of the bottom looking back to front.
    thanks rob
    AIRBORNE!!
  7. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    still need pics of the top...the bottom is done and good to go, its the top thats boggling my mind [​IMG], i just cant grasp the concept of the angles!! i did finally get everything welded, filled, sanded and primed...looks pretty damn good for me (i aint no body man, but have messed around with it in the past!!) the top will have to be filled this week, as i need to get some 1'X1" square tubing to weld in....how do i connect a rollbar to the window frame??
    AIRBORNE!!
