Roof POP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85 blazer, Nov 4, 2002.
  1. 85 blazer
    85 blazer 1/2 ton status
    Feb 12, 2002
    118
    Avoca NY
    I did some wheeling first time with Blazer and went over some off camber ruts where the rear tire was 3 feet in the air and the roof popped is this normal???
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Mine used to pop and bang all the time before I removed it. It did this for years with no issues. I wouldnt worry about it.
  3. Grim-Reaper
    7,385
    Atlanta
    Hehehe yeah the do a fair amount of complaining and shifting around. I have a steel body pannel in the 79 that would make a bang that I can only describe as sounding like somebody bounced a basket ball off the side of the truck LOL
    It's loud too. People out side the truck always turn and look when it does it and go WTF was that. I think it's either the inner roof pannel or the inner fender doing it.
    If your truck has rust (well even if you don't think it does) check the tail pan. They will rust out and start folding when off roading.
  4. 85 blazer
    Feb 12, 2002
    118
    Avoca NY
    New tailpan this year and fenders and inner fenders and doors rest was all good, was just curious about the roof pop!!!!!!
  5. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    mine's popped ever since it was stock. changing out the body mounts to poly's helped some. when i box up the frame a bit it'll prob fix it. i believe its caused by the frame flexing and twisting up the body.
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    It is normal. When you start to flex the body it will make popping sounds from the roof.
