Roof Rack Pics
Discussion in 'The Garage' started by nschingeck, Jan 19, 2007.
  1. nschingeck
    nschingeck Registered Member
    Jul 12, 2006
    23
    Colorado
    Here is some pics of the roof rack I built. Thanks to CK5 for all the great info, couldn't have done it without.:bow:
  2. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    looks great. did you make it easily detatcheable if you want to go convertable?
  3. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    thats a sweet 79 nice truck and roofrack
  4. nschingeck
    Jul 12, 2006
    23
    Colorado
    It's 4 U bolts and a QD for the lights so it should come off pretty quick. I'm gonna ditch the top completly in the spring, put in a cage and i'll attach it to the cage.
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Nice rack. I'm wondering why its mounted so high, but guessing that its so you can get it off easy like Colby asked.
  6. nschingeck
    Jul 12, 2006
    23
    Colorado
    The PO had the bar racks already mounted so i just attached it to those because it was easy. I saw yours in alot of the threads I searched looks great and good info, helped alot.
    Nick
  7. Kg6kjs
    Kg6kjs Registered Member
    Nov 18, 2006
    33
    Glendora, Ca
    Looks good. Thats what I want to make next after my bumpers are done. Did you build it or buy the rack? If you bought where did you get it?
  8. nschingeck
    Jul 12, 2006
    23
    Colorado
    Built it, I was just looking at your bumper thread those are sweet. You should have no problem building a rack.
  9. Kg6kjs
    Nov 18, 2006
    33
    Glendora, Ca
    Thanks, I was thinking of building to 1" tubes under the shell 1 front one rear to to bolt threw the shell into the tubes. Making the tubes support the rack. So I can put my spare and camping gear up there.
  10. nschingeck
    Jul 12, 2006
    23
    Colorado
    That's a good idea that way your not depending on the fiberglass if you really load it up. If your gonna put two hoops in you might as well build a cage:D Thats what i'm planning on doing.
  11. Kg6kjs
    Nov 18, 2006
    33
    Glendora, Ca
    Well, I was going to build a cage but I am putting in a bench seat up front and removing the rear bench for ever. So I figured I don't need a cage in the back. I am making a mini cage for the front so the bench seat will have 3 sets of 4 point seat belts.
  12. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    How is the rear of the rack attached to the cap? Did you drill through the fiberglass?
  13. cbbr
    Jul 17, 2004
    14,681
    I would have done the exact same thing. Looks like a really stout rack.
    Mine is due for a rebuild soon since I flopped and bent it up. I think that I may use the expanded metal, it looks great. How is the road noise with it?
  14. nschingeck
    Jul 12, 2006
    23
    Colorado
    The bar racks were already on there from the PO he attached it to the fiberglass with threaded inserts, they don't actually go through the roof all the way.
  15. nschingeck
    Jul 12, 2006
    23
    Colorado
    I have all the interior stripped so its not a real quiet ride but it didn't get any louder with the rack.
