Roof seal?
Discussion in 'The Garage' started by IDGMC, Feb 21, 2005.
  1. IDGMC
    IDGMC 1/2 ton status
    Feb 18, 2000
    150
    Idaho
    Hey were can I get a new roof seal for my 91? Its all dried out and ready to be replaced.. Also my e-brake light at the dash stays on. Why is this? Is the truck smart enough to tell me I have a problem or just a bad switch at the e-brake pedal
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    LMC Truck for the seal
    Parking brake, brake cable may need adjustment, check accordingly.
  3. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Or your Master cylinder could be low on fluid.
  4. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Or I think 91 has ABS, so it could be something with that.
  5. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Disconect the battery cable for a few min. , this will re-set the electronics and the light will go out
    The light will come back on if there is still a problem
    I have done this a few times on my 91 Jimmy and it works , I have never found anything wrong with my rig :confused: ,it just acts up on occasion
    I think the problem with my rig is mud running /ice and snow cause things to screw up with the anti lock:dunno:
  6. dyeager535
    26,975
    Go with GM for the seal.
    Forget LMC regardless if the price is double. Some LMC seals might fit, my experience has been that construction quality sucks, and so does attention to detail.
    Cheap has no place when something is more than just for looks.
