Rookie Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ArrowheadK5, Aug 31, 2001.
  1. ArrowheadK5
    ArrowheadK5 1/2 ton status
    Aug 3, 2001
    252
    Northern MN
    What is the difference between 3:73 axles and 3:03?
    Four wheel drive, four wheel expenses...
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I think you mean 3:08. Anyway 3:08 are a taller gear 3:73 are lower.The gear ratio depends on what you will be doing and what size tires you have.....Dan
    If it ain't broke.......Don't fix it....
  3. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    3.73 is your gear ratio. If you search this forum on Gear ratio you will find a wealth of knowledge. Basically, this is the ratio of the set of gears in the axle differential. What it means is that for every 1 rotation of the tires, the driveshaft will rotate 3.73 times. If you have 3.08 gears, the driveshaft rotates 3.08 times for each revolution of the tires. The lower the ratio (numerically), the faster you can go top end, but you will have less get-up-and-go and could eat up your transmission. The higher ratio (numerically), the more "power" you will have, but the slower oeverall the vehicle will go.
    Typically with offroading and oversized tires, the larger the number the better (to an extent). This will transfer more power to the ground at slower speeds. Afterall, most offroading is done at low speed, not high speed. And you usually need low-end power more with a 4x4 than high-end speed.
    This is just a nutshell explanation. Like I said, search this forum for gears or gear ratio or somethign like that and you will find a whole wealth of knowledge.
    Brian
    Click to see <a target="_blank" href=http://tx85gmcguy.alloffroad.com> My 85 Jimmy </a>
    Who put a stop payment on my reality check?!?
  4. ArrowheadK5
    Aug 3, 2001
    252
    Northern MN
    I meant to type 3:07, sorry. This is what I was told this Jimmy I'm looking at has on it now.
  5. ArrowheadK5
    Aug 3, 2001
    252
    Northern MN
    I think I understand now-thanks guys!
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    3.07 gears and big tires make for a truck that's miserable to drive. Add at least $1,000 to the price of the rig to allow for changing the gears if you want to go the big tires route.
  7. 1990SilveradoK5
    1990SilveradoK5 1/2 ton status
    Jan 2, 2001
    185
    Napoleon, OH
    I agree with HarryH3 I have 3.08's and only 33's and my get up and go has got up and went.
    Gotta get those 3.73's under my truck but the $ is just not available.
    Gone Large and Loving It.
    Keith
    Manchester, MI
  8. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I had the 3:08 with 33 inch tires. I had no get up and go. I put in 4:56 and I love it.......Dan
    <a target="_blank" href=http://coloradok5.com/gallery/Gokartergo>KLICK</a>
  9. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    i also had 307 gears and 33 inch tires and i had to make an appointment to leave the stoplight
    now i have 4.11's and the thing has plenty of go and still gets almost 17 mpg on the highway at 75 mph
    if changing gears anyway i would rec going with 4.11 over 3.73 if you have an OD tranny
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  10. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I have 3.08s and 35s. Mines not bad, but my mtor has alot of torque. If you motor is stock or has alot of miles on it, it will very slow when you take off.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  11. 1990SilveradoK5
    Jan 2, 2001
    185
    Napoleon, OH
    Thanks for the advice, I have not totally made up my mind yet on the gearing. Will depend on what I find diving at the salvage yard. I would like 4.11's, can I find those in a stock truck rusting away in a yard?
    Keith
    Manchester, MI
  12. ArrowheadK5
    Aug 3, 2001
    252
    Northern MN
    Hey, what gears are on a stock 79 k5? 87?
  13. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    It depends on what the original owen choose. They could be 2.73s, 3.08s, 3.42s, 3.73s, or 4.10s. Most likely it came with 2.73s or 3.08s.
