Rotated my 241 tonight
Discussion in 'The Garage' started by sled_dog, Mar 12, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I spent the afternoon removing the 241 from my Burb and puting it in the buggy. Used my rotation ring from DP_90K5 and rotated it all the way.
    As you can see its almost totally tucked in between the frame rails of the buggy. When I fab the new crossmember I will move it up a little more and hopefully tuck the tcase fully into the frame rails. The picture between the rail and the case was to illustrate how much space there is for the exhaust(much more than I anticipated). Picture doesn't show it very well though, there is a good 5" I would say between the case and frame. More than enough room for my 2.5" exhaust to be fabbed around it.
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Looks great!
    Bill
  3. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I did mine today too. But mine hangs down about an inch form the frame. If I were to raise it any higher I would be into the floor board so I am cool with it. As it is now I already had to massage the floor board with a BFH and I have a 2" body lift too. My Catalic converter is right next to the t-case so I can't go straight with my exhaust unfortunately. I am thinking of either going over teh front d-shaft or maybe just redoing my entire exhaust and going straight back and moving the cat and muffler back a bit. haven't decided yet. /forums/images/graemlins/dunno.gif
  4. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Uhh, whats rotating the T-case do /forums/images/graemlins/doah.gif /forums/images/graemlins/thinking.gif
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    gained about 4.5" of ground clerance.
  6. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    Man that looks good.
    Can't wait to get mine! But now I'll need to get a new y pipe fabbed up since it will hang so low. /forums/images/graemlins/doah.gif
  7. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    It's pretty awesome isn't it?
    I just put my case back in, had a leak I had to take care of /forums/images/graemlins/frown.gif
    This is def. on the top of my list for best mods to my truck. I wish I had done this a long time ago. The front shaft is still gonna be a bitch, but I've worked around bigger problems /forums/images/graemlins/grin.gif
  8. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    What does rotating the t-case do? Is it possible to do to a np205? What about drivetrain, wont that mess it around??? /forums/images/graemlins/1zhelp.gif
  9. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    Are there any oiling problems associated with clocking? How do you change or add fluids?
  10. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    Will your exhaust cause you to vapor lock due to the pipe being so close to those metal fuel lines? /forums/images/graemlins/dunno.gif Hey where can I get one of those clocking rings? How much? Did you need any extra materials?
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    change or add fluids the sameway. Maybe tilt the rig a little to make it all easier, since mine is clocked all the way. Have to remember in most cases you guys wouldn't clock so far, you'd have to cut a hole in the body. I am not reusing those fuel lines so no worry there. Fuel cell is going in the back and will be plumbed through the "cab", so I can have a fuel shut off just in case.
  12. scoutillac
    Feb 24, 2004
    423
    Spokane, Wa.
    What about how to get one of those rings so I can rotate the one in my burb and my scout? /forums/images/graemlins/burb.gif
  13. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    dp_90k5 I will look for the original thread. I believe it was $109 shipped, not sure if that will change after the first run.
  14. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
  15. Esteban86K5
    3,712
    Bakersfield, CA
    I didn't have to cut a whole in my body with it clocked all the way. I just massaged it a little and it's fine. /forums/images/graemlins/waytogo.gif
  16. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    If anyone is interested, I still have some of these... /forums/images/graemlins/waytogo.gif
  17. CK5
    May 19, 1999
    21,623
    701
    CO
    Did you use a longer input shaft or do you just have less spline engagement now?
  18. Kyle89K5
    2,273
    OKLAHOMA
    I've got less spline engagement. I spent about 2 weeks going back and forth with New Venture Gear and they helped me reach the conclusion that the loss of spline engagement is marginal. They pulled all of the original prints and design calcs to find the amount of "error" built into the spline engagement and came to the desision that the loss of 5/16" is not an issue.
  19. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    wow that great news.. /forums/images/graemlins/waytogo.gif
    that was a concern of mine. i may have to get one now to clock my case. /forums/images/graemlins/peace.gif
  20. skratch
    Oct 28, 2003
    1,646
    Gorveport, OH
    How many you got left, and when will you be doing a second order?
    I may have the money in the next couple of weeks.
