Rotating a front axle (pinion).
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jwduke, Dec 28, 2002.
  1. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    /forums/images/graemlins/1zhelp.gif I'm needing to rotate the front axle (pinion) up 10 deg., on a D44HD. Do you cut, and reweld the axle housing ends & install 10 degree shims under the springs, since you can't move the passenger side spring pad, or what??? Thanks! /forums/images/graemlins/1zhelp.gif
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    SHIM IT! /forums/images/graemlins/thumb.gif
    -Dan
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just so you know, you're ruining your caster angle when you do that. I'd live with the crappy angle if I were you...or split the difference and only shim it up a few degrees.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    to do it right after you set your pinion angle, you cut the welds off the knuckles and rotate them to the correct caster
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The proper way to adjust that far (10 degrees) would be to remove the driver's side perch and put another one on at the proper angel, then have the passenger side perch milled to the same angle. Then you cut off the "C's" on the ends of the housing and reweld them at the proper caster angle. </font color>
