Rotating D60 Pinion
Discussion in 'The Garage' started by ChadH82, May 24, 2004.
  1. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    Well the blazer is getting close to running so I'm starting to think about driveshaft now. I need to rotate my pinion on my D60 but I don't have the expertise to cut and reweld the knuckles and remove the axle tubes and rotate the pinion. I want to do things right but is there an easier way to do this? My atlas is clocked as much as possible and I still need to run a CV shaft. Are there and shops in the Oklahoma City area that have done this before?
  2. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    You can put degreed shims between the spring pads and springs. Cant go too far though.
  3. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    The only one close that I can think of would be WMS. Not that I have a lot of knowledge w/OK shops. /forums/images/graemlins/histerical.gif
  4. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    OH yeah I almost forgot you may also need different spring plates if you use degree shims underneath. Thanks to them nice two bolts that go straight into the housing rather than a ubolt. DP90K5 makes some really nice ones.
  5. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Whoa... it's been a long time since you have posted here! I think I remember your blazer, didn't you also have a blue Z with a SFA on 38's? What have you been up too lately?
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the only hard part is how the new PS spring pad and studs are done
    make the shop explain exactly how they are going to deal with that area and then decide if you are satisfied with their method
  7. bigblazer433
    bigblazer433 Registered Member
    Jul 29, 2002
    38
    El Reno Oklahoma
    I would call custom off road equipment in OKC its right off I-40. I have had them do allot of work for me. Ask for Jerry at 405-943-2673. I think he has done this to his D60 /forums/images/graemlins/waytogo.gif
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    If you use A BIG of degree shim, well then there goes your caster.
    The best thing, if you want to rotate it a lot, would be to get it indexed up. /forums/images/graemlins/thumb.gif
  9. ChadH82
    May 9, 2001
    400
    Ya that's me... I sold the Z for something more driveable. College kind of took over and got me out of the loop for a couple years. I should be started the Blazer this week. Here's the specs.
    73', 383,400, atlas II, D60, 14 bolt, 39.5 swamps, rockstomper beadlocked wheels, blah blah.
    I have pics if someone can post them. It's kind of embarrassing how shiny it is. It needs some dings.
