Rotational grinding when braking??
Discussion in 'The Garage' started by 81jimmyslt, Oct 5, 2005.
  1. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    When I brake hard I get a horrible rotational grinding noise, the harder I brake the louder and harder it grinds. I have a NP 208. There is another post I replied on about grinding when deccelerating, this is related but my truck is undrivable so I made another post. I moved the axle back 1.5" because the driveshaft was to long, I thought the grinding was when I was braking hard and the shaft was bottoming out. Still grinds like crazy but my slip yoke driveline output looks perfect now. It was also suggested to lower my tcase again, but I don't think that will fix it.
    Any Ideas?
    Jesse
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    are your brakes ok?
  3. 81jimmyslt
    Jun 5, 2003
    1,643
    Brakes are fine it sounds and feels like the t-case.
  4. 81jimmyslt
    Jun 5, 2003
    1,643
    Bump, and no my rear pinion nut is not loose.
