Rotella in a V-8 Gas engine?
Discussion in 'The Garage' started by chalet2506, Aug 31, 2006.
  1. chalet2506
    chalet2506 1/2 ton status Premium Member
    May 9, 2006
    4,931
    Skeddadlin
    Any opinions on using Rotella T 15w-40 in a 400sb with about 100,000 miles and some pretty good leaks. I need to change the oil today and I've got a case of it handy.
  2. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
    I used to to use Rotella in my Harley if that helps it was a 77 FX.
  3. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Isn't that some sort of pasta?
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    When they were out os 20w50 I have used 15w40 . And I had over 100,000 miles then .
  5. Metrodps
    Jan 4, 2006
    9,726
    108
    earth
    Applications
    • Heavy-duty diesel and mixed fleets in all types of< over-the-road service, including engines with EGR
    • Recommended for diesel-powered equipment, including those powered by Caterpillar, Cummins, Detroit Diesel, Mack, Mercedes-Benz, International and Volvo engines in all types of service
    • Off-highway applications where an all-season, universal engine oil is desired, such as construction, mining, logging and agriculturual service for manufacturers, including John Deere, Case IH, Komatsu and Agco for manufacturers• Heavy-duty transmission applications requiring Allison C-4
    • Many gasoline engines, especially the hard-working engines of pickup trucks, sport-utility vehicles (SUVs), minivans and motorcycles
    • Passenger cars, light trucks, farm equipment, forklifts and assorted stationary equipment with automotive type LPG- or LNG-fueled engines where ashless or low-ash oils are not specified by the manufacturer
    • Detroit Diesel Series 53, 71 and 92 engines operating in ambient temperatures below 0°F use Shell ROTELLA® T SAE 15W-40
    http://rotella.com/products/rotella_t.html
  6. chalet2506
    May 9, 2006
    4,931
    Skeddadlin
    Rotella it is.
  7. Metrodps
    Jan 4, 2006
    9,726
    108
    earth
    Wisely choosen have you!
  8. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    Diesel oil is better!..
    Since I got my 82 K20 with a 6.2,I've been buying Roatella "T" in two gallon jugs or 5 gal. pails,and have been using it in my gas powered vehicles too...the only thing you have to worry about is the higher detergent content MAY loosen sludge deposits in an older high mileage motor that didn't get frequent oil changes--it could cause damage...
    My motors are clean,the 305 in my 79 C10 had the oil pan off to change the oil pump and timing components,and a new pan went on,as the other was rotted and leaky--so no sludge worries!..I notice the oil darkens quickly the first time you use it--shows the detergent is working!..Also noticed less consumption in engines that use some oil,compared to "regular" dino oil...:crazy:
  9. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    Used it in my 98 TaBlow with no problems
  10. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    not sure on gas moter. never used it, but it goes into all my 6.2s.
  11. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    Unlike most current spec oils, it actually has a good bit of EP additives, so it's great for flat tappet cams. Go for it.
  12. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,603
    555
    Wasilla AK,
    that's what goes in my burb and my superduty there both gassers . I run delo 400 in my 6.5 but only beacause it's always had it and I'm afraid to change it
  13. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    Ive ran rotella in both motors in my truck and my dad uses it in his truck, all 350 gassers. in my old motor it did like was mentioned before and caused a bunch of sludge and stuff to break loose and it started using more oil and leaking really bad but on my new motor it has done great. not sure if it would have the same effect on your older motor cause mine had well over 100,000 on it. It had hardly any compression at all, you could turn the motor by the flywheel with one hand so Im pretty sure it was completly worn out.
  14. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    I have a 400 SBC that is gettin rebuild and bumped up a few notchs. I had planned on Rotella T for oil, what weight do you guys recommend?
  15. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    it turns into a watery substance after you run it for awhile,,,then it'll eat cams and lifters :crazy: at least it did mine when i ran it, drained it out, looked like black water.
    I personally won't use it again in a gas motor even if the container says you can use it there.
  16. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am have been using Valvoline Premium Blue (diesel oil) in the K5 for several years now. It works well for me. No problems at all that I can see. I may swap it over to Amsoil now that I am Amsoil dealer though.
    Harley
  17. Metrodps
    Jan 4, 2006
    9,726
    108
    earth
    Like I said I have used it in a Harley I owned and if I knew how clean my motor was in my Blazer now I would not have a problem with using it. We have seen several post that show people using it and liking it. If it caused damage to motors I do believe they would not list it for gasoline engines.
    I used it in my Harley and rode to Sturgis SD twice and also idled in 100* temps for several periods. Keep great oil pressure in it.
  18. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    it only comes in 15 w 40
  19. bandit4369
    bandit4369 Registered Member
    Mar 20, 2006
    82
    Nw. Pa.
    If you have a diesel it's the best thing going. It's all I've run in my Rigs for 30yrs. I have a 550 cat in my W. Star that has 1,160,000 miles and has never been babyed or rebuilt. At a million mile I got nervous and put rods and mains in it, the old ones were still in good shape. You need to remember though, Rotella is designed for an engine that's working range is 1200-1800 rpm and doesn't turn over 2100 rpm, not 5 or 6000. I have cases of it but wouldn't put it in my BBC.
  20. TeK
    TeK 1/2 ton status
    Jan 3, 2005
    170
    Greenwood, IN
    been running Valvoline for the longest time and figured I'd try the rotella since its cheaper. been using it ever since in everything from quads, motorcycles, drag cars, to my getting currently rebuilt 454.
