Rotella T
Discussion in '1982-Present GM Diesel' started by OFFRDK5, May 5, 2003.
  1. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Just wondering if anyone uses Rotella T in other stuff other than their Diesel. Seems it meets the requirements for my daily driver's oil, and if it can handle a 6.2 it should be able to handle a 3.8 gasser?
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Are you getting it by the 55 gallon drum? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  3. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    I should be. Its cheaper!! But I don't have the green funding to get that much. Plus I don't think my apartment complex would like to have a 55 gallon drum of oil in my apartment!! How long would that take me to use up?
  4. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Wrong viscosity assuming you are talking about 15W40 Rotella.
  5. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Yea, its just a bit thicker, but its not like I would be running gear lube in my crankcase!!! How much would it affect things, since you are the engine expert?
  6. BlueBlazer
    Feb 15, 2001
    1,940
    Youre oil pressure would be sky high most likely, your oil pump will probably wear quicker cause its working harder, you will have more parasitic drag from the thicker oil, etc. etc. There is a reason most cars call for 5W30 or 10W30. And no, its not just a little difference between 5W30 and 15W40.
  7. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I run 15w-40 Mobil in just about everything.
    Come summer time I'll run it in my quads, warrior calls for 10w-40. Run it in my LeSabre, no oil pressure issues(summer), 10w-30 in winter.
    From what I've read if you have oil consumption issues it could poision your converter. That's from the higher amounts of anti-wear and detergent additives.
    Plus I buy it in 10qt containers and I don't have to deal with so many 1qt bottles.
  8. BlueBlazer
    Feb 15, 2001
    1,940
    Do what you want, but its obviously not whats best for your engine.
  9. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    About how long have you been doing this? What engine is in your LeSabre? I got the 3800 and it just screams for me to open it up!!
  10. Diesel Dan
    Feb 27, 2002
    798
    Warren, Ohio
    I have the 3800, only engine offered in the Parks/LeSabres.
    My brother in-law runs 15w-40 in his Hi-Po 454 instead of 20w-50.
