rotisserie for blazer tub
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by muddbudd72, Dec 19, 2003.
  1. muddbudd72
    muddbudd72 Registered Member
    Dec 3, 2003
    55
    port allen louisiana
    has anyone built or have plans for a rotisserie for a blazer tub? im doing a frame off and want to clean and paint my underside or line/x if i can. thanks and have a MERRY CHRISTMAS to all.
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    WHAT???
    rotisserie? Isn't that used to cook chicken?
    Maby the DayQuil is affecting my brain.....
  3. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    There are companies that make them. I would imagine they are expensive. Didn't they use one on "TRUCKS" when they were building project Crazy Horse?
  4. Robin
    Robin 1/2 ton status
    Oct 30, 2001
    184
    Georgetown, Texas
    Actually I found the body was easy to coat underneath (once the chassis was rolled out).
    When you have the frame dissassembled, you can flip it easily to get around all the difficult to reach spots. I think a rotisserie is an unnecessary luxury...
  5. Burt4x4
    6,854
    Ohhhh I get it now...dauuu
    heheh told you the dayquil is bustin my brain heheheh
    That is one big chickin cooker heheheh
  6. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    Ok, I'm so far lost on this I can't even think of something funny to type... /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/thumb.gif
  7. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    He's talking about a stand to which the front and rear of the tub can be affixed so that it can spin on an axis. This would allow you to just push it a little and spin it over so that you can coat the underside of the tub. It is similar in theory to a chicken rotisserie, or one of those garbage cans with the dome tops that have the flap that spins around.
    -Andrew /forums/images/graemlins/usaflag.gif
  8. Stroked72Blazer
    Stroked72Blazer 1/2 ton status
    Nov 9, 2002
    352
    Little Rock, AR
    If you are still interested I will try to dig up the old Hot Rod that they used one on a Biscain. You could use that as a cheat to fab one up. But I would hesitate to put the tub on one because I would be afraid of it folding in the middle. I am interested to find out if I'm correct or not because I would like to do the same thing when I do a frame off on mine. But that will be a while as I need to build a house first.
  9. muddbudd72
    Dec 3, 2003
    55
    stroked yes im still interested. my tub had very little rust which i replaced while it was on the frame. so im hoping that it is pretty stable. i plan on welding braces in the door opening. this may seem like overkill but this truck was in good shape and would like for it to be around for a lot longer. thanks for the replys.
  10. Stroked72Blazer
    Nov 9, 2002
    352
    Little Rock, AR
    I found the article where they separate the body from the frame in the July 2001 issue. The rest of the story in the August 2001 issue I think but I can't find that one. You can check with www.hotrod.com to find the rest of the story. I need your e-mail addres so I can send you a scan of the article.
  11. bouncytruck
    Oct 11, 2001
    858
    Bothell, WA
    lol
  12. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    A luxury yes, but worth it. Helped a friend with one restore a Mustang. He had castor wheels on it too. Got it out of the way when needed. I'd go for it...
  13. earl87gta
    earl87gta 1/2 ton status
    Apr 6, 2003
    551
    Chuckey TN
  14. muddbudd72
    Dec 3, 2003
    55
    stroked...thanks for the reply. my email is muddbugg72@aol.com thanks.
    earl87...lots of info in those articles i really appreciate it.
    again thanks guys i think i can come up with something from this info.sorry for the no reply in a while,been down in my back.
