rotor for 1/2" lug stud???
Discussion in 'The Garage' started by rcurrier44, Apr 29, 2005.
  1. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    Well the drum brakes on my new 61 3/4 ton Eaton rear are shot. So I want to go to disks on this one. Unfortunatly the chevy 3/4 ton 4x4 rotors use a 9/16 stud but my hub uses a 1/2 inch stud so the studs are realy loose :(
    I could redrill the hub for bigger studs... or redrill the rotor for smaller studs... but I would rather find a stock part that would work.
    So, does anyone know of a 8 lug disk that uses 1/2" studs??? The guy at napa was no help and coulden't/woulden't help me this morning :mad:
    ROB
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Ford used 1/2" studs on the 3/4-ton trucks (I think). Start go to the parts store and look for some F250 4x4 rotors.
  3. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Yeah, look for various year Ford stuff. You have to make sure the hat and the rotor thickness is right though.
    You could also try later model stuff. It'd be metric, but it'd be real close.
  4. rcurrier44
    Oct 13, 2003
    320
    Ah ford stuff... didn't even think of that. I'll try them.
