Rotor ID
Discussion in 'The Garage' started by johnnychimpo, Sep 10, 2006.
  1. johnnychimpo
    johnnychimpo 1/2 ton status
    Oct 9, 2005
    1,145
    Nash, TN
    Can anyone ID the rotor on the left. Would it happen to be a SRW D60.A friend gave it to me for my K20,but I did'nt look closely when I picked it up.
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Yep, looks like a 60 hub/rotor to me. The HD versions of the 44 doesn't stick out as far, if I'm making any sense....
  3. johnnychimpo
    Oct 9, 2005
    1,145
    Nash, TN
    Sweet! part 7 of my evil plan begins. I had a set of the HD d44 rotors and they had external hubs if I remember correctly.
  4. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Yes, that is definately a D60 rotor and hub, but the studs lead me to believe it might be from a Ford 60. Spacing on the rotor could be different, I don't know as I haven't compared them side by side yet.
    Jimbo
  5. johnnychimpo
    Oct 9, 2005
    1,145
    Nash, TN
    How would I tell if it came from a Ford. If it is, Would it still be usable on my chevy D60.( question mark key disabled 4yr old + Sprite= sticky laptop!)
  6. johnnychimpo
    Oct 9, 2005
    1,145
    Nash, TN
    If someone has a pic of SRW D60 hub-rotor, post it up. Things can't possibly be going this good! I have to know if this is a chevy hub-rotor.
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    D60 SRW for sure. Measure the thickness of the rotor or look inside near the inner bearing and it should tell you the min thk., GM use a 1.5" thick rotor and dodge IIRC uses a 1.25" thick and i'm not sure about the ford.
  8. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    A pic will still be hard to tell as the major diff between Ford and Chevy/Dodge is the length of the snout.
    Check the stud dia, as far as I know all Fords used 1/2" studs while all Chevy's used 9/16". Not sure about Dodge stud size but the odds of it being an 89-93 Dodge hub assembly are slim.
    I agree with Jimbo that it looks like a Ford, all the Fords I have seen had that little bald step at the outer end of the stud.
  9. johnnychimpo
    Oct 9, 2005
    1,145
    Nash, TN
    Thanks for all the info. I just have to sucker him out of the other one!
  10. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    thats off a ford. you can see the studs in the pics.
