Rotor question - (ignition system rotor)
Discussion in 'The Garage' started by heavy4x4, Dec 3, 2002.
  1. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    This is on a '90 TBI 350. A while back, I bought new plugs, wires, cap, and rotor. I did the wires, and went to replace the cap and rotor...well, the rotor wouldn't come off the distributor. It was like it was just really stuck on there. I pulled on it pretty hard with my hands, and it didn't budge. I didn't pry at it with any tools. So, I said screw it and just put the new cap on - leaving the somewhat worn rotor in place. My question is...was it just stuck on there - there is no set screw or something else to worry about...right? Should I just take a pliers and grab onto it and pull? Thanks in advance for your input. Just figured I should change it to the new one for some better gas-mileage.
    Also, to answer two of my questions with one post...when did Chevy quit using HEI distributors? Mine is just a plain cap with a short wire coming from the center and going to the coil. I was kind of surprised seeing this instead of the HEI setup.
    Thanks again.
  2. heavy4x4
    Aug 28, 2002
    3,270
    ttt -- common, all, this is an easy one /forums/images/graemlins/smirk.gif
  3. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    Your rotor is just stuck. I had to break mine up with some pliers. I don't know why GM quit using HEI. could be when they started using a computer. Could be size considerations.
  4. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Chevy didnt stop using HEI. HEI just means High Energy Ignition. The newer style is still HEI, but the coil is external instead of internal.
