Rotor removal on a full floating axle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by aksidentproan, Jul 11, 2003.
  1. aksidentproan
    aksidentproan 1/2 ton status
    Dec 8, 2001
    477
    Maryland
    I was working on a Chevy dump truck at work today with a full floating rear axle under it. The axle is some sort of dana. The truck needs new rotors and I was wondering how to remove the rotor. A little help would be appreciated.
    Thanks.
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    If it has "outboard" brakes it just slides off. If it has "inboard" brakes you have to pull the hub off and drive the studs out to remove the rotor. /forums/images/graemlins/thumb.gif
  3. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Like bruce said, some of the newer axles are designed so the drun/rotor just slides off...Some of the older full-floating axles, like the 14bolt full floater, you must remove the 8-bolts that hold the axle to the hub...Then pull out the axle... then you need a special hub nut socket (usually a 6-prong on the bigger stuff) to remove the outer wheel lock-nut...The remove the lock "ring" or lock washer and then remove the inner wheelnut...The the entire hub just slides off the spindle...It is VERY similar to removing the brakes on a front axle, save the axle removal...
    Chris
