Rotor Removal
Discussion in 'The Garage' started by matto, Mar 25, 2005.
  1. matto
    matto Registered Member
    Feb 20, 2005
    49
    uncasville ct
    How the heck do get the rotor off the front axle? It is a 10 bolt original 6-lug.
    We have the locking hub removed and the manual says the rotor should be able to come off but the bearing seams to be in the way.
    Thanx
  2. convertaburb
    convertaburb Registered Member
    Dec 22, 2004
    9
    las vegas nv
    after the hub comes off you have to remove the two locking spindle nuts then the bearings.
  3. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    you have to remove the spindle nuts. you should have 2, an innner and an outer. they make a special tool, but if your careful, you can get it off with a hammer and punch
  4. matto
    Feb 20, 2005
    49
    uncasville ct
    Got one nut off, it has 4 notches in it. It looks like the only thing left is the bearing.
  5. dyeager535
    26,979
    If it helps, there is a 10 bolt exploded diagram and parts listing here
  6. matto
    Feb 20, 2005
    49
    uncasville ct
    We knew we could count on you guys! Thanx. What looked like a bearing was a washer hiding the second nut! Thanx again
  7. ksfirefighter_1983
    ksfirefighter_1983 Newbie
    Feb 16, 2012
    kansas
    im have problems with mine to and its my bearing how do i get hub/rotor off with the bearing seized on
  8. dremu
    Feb 27, 2000
    15,957
    446
    East of San Francisco
    Heat (knowing that there's grease in there which is flammable) or a hammer. If the bearing is rusted to the spindle or the like, the spindle surface may be shot and you may end up replacing the spindle as well.
    -- A
