Rotor wont point same way after dist R&R
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, May 19, 2001.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I took the distributor out of this guy's truck, marked the location of it, and sat the rotor pointing the direction it was on the dist, replaced the pick up coil, and the distributor wont go back in right....its about 60 degrees off. Anyone know what I did wrong?
    90K5
  2. silver 90
    silver 90 Registered Member
    Dec 4, 2000
    14
    Nebraska
    The oil pump shaft has probably rotated out of place. The bottom of the distributor has a piece on it that fits in a slot on the shaft that drives the oil pump. You need to pull the distributor back out and turn the oil pump shaft to the correct position. All you need is a long flat tipped screwdriver to turn the shaft. Good luck.
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Thanks - I know exactly what piece you are talking about. I'll fix it tomorrow.
    90K5
