Rotors - how thin is too thin
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beater74, Jul 11, 2002.
  1. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    how thin is too thin for a rotor? i have dana 60 rotors and the fella who i had turn them says one is 40 thou. too thin but since i'm good friends with him he turned them anyways. He says along with several other folks that it is fine for now but thats the last turn i'll get out of them. what do you think?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The brake system is one place that you NEVER want to scrimp. The rotors have a minimum thickness rating for a reason, and it isn't just to sell more rotors. /forums/images/icons/wink.gif Those suckers get clamped very hard when you stand on the binders, and they go through a lot of heat and cooling cycles. Having one fail under heavy braking could be ugly. Start saving your pennies so you can replace the worn out rotor. /forums/images/icons/cool.gif
  3. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    BTW, the minimum thickness rating is cast right into the rotor somehwere. /forums/images/icons/cool.gif
  4. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    And if you cant read the spec on the rotor, any place with a brake lathe should have a book with the specs, both machine to and discard tolerances.
  5. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    I've noticed on rotors that are getting thin that they warp pretty easily if you stand on the binders with any speed. Thin would probably be OK for a while if you drive it like grandma does. I definitely would avoid autoX-ing or towing if you have any question about rotor integrity. Just a thought....
