rotors
Discussion in 'The Garage' started by tecton, May 3, 2004.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    after watching a trucks marathon and seeing how easy it is to change out the rotors, ive become curious on the topic
    bigger rotor = more stopping power, but at what point does it become excessive? if there a formula? or just get the biggest rotor i can afford?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Good luck fitting a bigger rotor inside your 15" wheels.
  3. tecton
    Dec 1, 2002
    1,553
    WV
    so wheel size comes into play
    is it possible to move the brakes further inside the axle?
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not any measureable amount.
    If you want bigger brakes, get a bigger axle.
    If you're still half ton, convert your front axle to 3/4 ton for a slightly larger rotor.
    Dana 60 front has huge brakes.
  5. tecton
    Dec 1, 2002
    1,553
    WV
    lol
    15's wont fit on a d60 without grinding will they?
    i think ill just get a smaller tire
  6. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    You could upgrade to a larger caliper for more clamping force or you could change to a softer pad and a slotted rotor for better heat dissipation for less brake fade. Or you could upgrade to rear diskbrakes for better stopping power. That way you can run the same size tires front and rear.
  7. diesel4me
    Jul 24, 2003
    17,534
    920
    Massachussetts
    I wonder why they dont put the rotors on the pinion shaft,like the monster trucks--its supposedly 25 times more effective due to the gearing in the differential.Maybe it would lock the wheels to easy??.I have a golf cart rear axle with the rotor on the pinion right behind the driveshaft and it works great.Why not on passenger cars and trucks?? /forums/images/graemlins/dunno.gif
