rotten egg smell in 4WD
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by johnnieg, May 2, 2003.
  1. johnnieg
    johnnieg 1/2 ton status
    Nov 10, 2002
    130
    CSU, Ft. Collins, CO
    I was by Pueblo today and did some light wheeling. I went up a pretty steep hill then a couple of little bumps. on the way back down, I noticed a rotten egg smell. It has smelled like this before (aprox 2-3 yrs ago) and I replaced the EGR. Now when in 4WD it smelled rotten and when I went back in 2WD I couldn't smell it anymore. Could it be that it was just running rich or what? /forums/images/graemlins/k5.gif
  2. johnnieg
    Nov 10, 2002
    130
    C'mon guys /forums/images/graemlins/1zhelp.gif me out here. Any and all thoughts are appreciated!
  3. MUD JUNKIE
    MUD JUNKIE 1/2 ton status
    Oct 24, 2001
    379
    Reddick,florida
    do you have a manual tranny?
    the only egg smell I could think of is a burning clutch,just like what you said while climbing a hill,maybe you were smoking the clutch?
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    You'll also get a rotten egg smell from a cat convertor going bad.
  5. MudFlap
    MudFlap 1/2 ton status
    Dec 2, 2002
    250
    Winston-Salem, NC
    I second the vote for the cat.
    Trey
  6. rawhead
    rawhead Registered Member
    Dec 6, 2002
    52
    So. California
    I have the same problem. It doesn't smell unless I get into the pedal pretty good. I replaced the entire exauhst from the Cat back (needed it anyhow). I still get the smell. I believe the problem is the charcoal canister. Normally the smell is from a bad cat though. Tough call.
  7. JustHorsinArownd
    JustHorsinArownd Registered Member
    Mar 20, 2003
    77
    Flagstaff, Az.
    I'm with the clutch guys. Seems to me that you were probably feathering the clutch on the way up the hill and glazed it a bit. Especially since you said you only smelled it once a couple of years ago. Don't you worry about it just try to trust the ponies under the hood. /forums/images/graemlins/thumb.gif
  8. SickboySS
    SickboySS 1/2 ton status
    Nov 24, 2002
    154
    Auburn Ma
    its more than likely a cat, cuz when you're on it in 4wd its putting more of a load on the engine than in 2wd...also when you stomp on it in 2wd it puts more of a load on the motor and will produce the smell too
  9. RatMan
    RatMan 1/2 ton status
    Jul 27, 2002
    270
    Marietta, Georgia
    bad bateries can make a rotten egg smell too.
    sulfuric acid sucks
  10. Gary 86 K5
    Gary 86 K5 1/2 ton status
    Oct 7, 2002
    204
    Mentor, OH
    I can almost guarantee that its the cat. I've seen them go bad and reek like eggs many times. /forums/images/graemlins/k5.gif
  11. dyeager535
    26,982
    191
    Improper mixture will net you a rotten egg smell as well. BTDT, brand new converters can stink with an incorrect fuel mixture, typically when you've just got done really romping on it.
  12. johnnieg
    Nov 10, 2002
    130
    No manual tranny, stock 700r4. So it must be the cat. I think it's the original from '88, it's bigger than the muffler. oh well thanx y'all! /forums/images/graemlins/thumb.gif
  13. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    Let us know if it's the cat, or if you're just not rolling the windows down on the vehicle when farting...could be one or the other. Either way, it's from you hitting the gas /forums/images/graemlins/thumb.gif
