Rotten EGG smell?
Discussion in 'The Garage' started by LKJR, Feb 16, 2003.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    what could cause a rotten egg smell in the cab of an s10? not super bad but noticeable after driving for some time?
  2. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    I've allways heard that Cat. Converters will do that.
  3. 4x4 Cowboy
    4x4 Cowboy 1/2 ton status
    Dec 7, 2002
    236
    california
    thats what happens when you FART! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  4. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    I call those hangover farts,
  5. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    It could be the A/C system, if you have one. A weird, bad smelling fungus that grows in it because of the freon.
  6. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I vote on the cat too. I've had that smell before and it's not nice
  7. boots
    boots 1/2 ton status
    Nov 3, 2002
    183
    Foothills of CA (Mariposa)
    my first thought was my dawg, seems to havea bad case of gas tonight but then I realized you were in Texas so I don't think that's the case. My second thought was your cat, it might have a bad case of gas. Depending on your emissions controld hack the dang thing out, weld in a peice of tubing and go fer it.
    me
  8. gen1blazer
    gen1blazer Registered Member
    Jan 5, 2003
    13
    Clovis, Ca. U.S.A.
    I had that exact problem once, and found it to be the battery. I started to notice a rottem egg smell that I could not locate, and 3 or 4 days later my battery blew-up. What a mess, not easy to clean battery acid from the engine well. Check your battery ASAP. Goodluck!
  9. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    dont forget that it could be a joke you might want to look for a rotten egg
  10. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    could it be gear lube seeping out of the rear of your transmissiong tail shaft? and spraying everyware.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  11. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    When the engine gets "out of tune" the cat creates the rotten smell....I would trade it off for say a .....70's Blazer!
  12. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    I am a little confused, why would you put gear oil in a transmission?
  13. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    that is what you put in a manual tranny i believe. Atleast the SM465.
  14. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'd also bet on the cat. converter being your problem. We used to cut them off and either replace them with a patch pipe, or hollow them out and put them back on.
  15. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ahahaha /forums/images/graemlins/rotfl.gif
  16. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    An overcharging battery will smell like a rotten egg, like mentioned in a previous post, it will eventually blow up... Check your alternator voltage output.
    Unless you have a back window, I don't think your going to be smelling your exhaust. Can you normally smell exhaust when the rotten egg smell is not present?
  17. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    My '89 Cavilier exibited the same smell, turned out to be the catalytic converter.
    John
  18. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    My CAT smells like that when the motor is under load like going up a hill. I don't think it's anything to worry about
    Dan...
  19. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    I'll check the battery and see if that's it, it was under a load all day yesterday so...
