Rough Country 4 inch lift
Discussion in 'The Garage' started by tch777, Oct 8, 2004.
  1. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    Okay who is running one of these lifts?
    How does it compare to stock ride?
    I want to go 4 inch and would like a firm but not teeth rattling ride. Their price is really good but is it too good?
    Besides price what would I notice in going from a 4 inch block to 4 inch springs in the rear?
    Tim
  2. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    Rough Country is a well priced kit. But it is not the best, you will have a little rougher ride then with the stock set up and as far as the blocks you should let your $$ decide if you can go for the rear springs or not. I have never been a big fan of blocks. The 4"kit is not made to go out and flex all over everything in site but it will work pretty well in the mud. You can also help the ride a little with a higher quality shock but it will only help some because the springs are going to be on the stiff side.
    Good luck with your purchase,
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It's going to be very firm. I'd suggest something besides Rough Country, Pro Comp, or Genuine unless you're going to have a big block and a heavy bumper.
  4. gotmud77
    Aug 4, 2003
    689
    bellefonte
    I just noticed that you also have a f350. I am asumming the lift is for the sub. It should ride very similar to the f350 if you decide to go with the rough country lift.
  5. tch777
    Jan 15, 2003
    244
    Yes lift would be for the Sub.
    Thanks for the replies.
    Tim
  6. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    If you talk to most people that have actually owned RC springs, they will say they ride better than stock, but maybe not as good as higher dollar springs. I was very impressed with mine for the money, impressed enough that they are on my new trail rig now.
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    My buddy has it on his Sub . Better than stock ride . It is of course not as soft as people here prefer , but I ride in it occasionally , and I like it , it is a truck after all . Helps the front sway too /forums/images/graemlins/thumb.gif
  8. woods
    woods Registered Member
    Feb 18, 2003
    73
    I have 4 inch rough country kit with the shocks too, it's rides a hell of alot better then stock did, my friends who are used to new cars/trucks/ complain about how it bounces alittle on big bumps, but I'm very please with the lift considering my old springs were starting to sag on the driver side,
    and whats great about the new lift if you know your going to be hitting a decent size bump around a corner you can throw people out of the pass seat, I got a 210 lbs guy 6 inchs into the air and he landed on the middle console, I about pissed myself laughing when that happened.
  9. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    i have the rough country lift , and i am happy. it rides better than stock. some say its bouncier, and it is , but i like it. if i wanted a cadillac ride , i would have bought a cadillac.
    i bought the blocks at first , becouse i was going to get the echobit flip. well we all know how that idea went belly up , so i ended up buying the rear springs a month ago cause the old ones were sagging. if you have any sag , i would do the same . plus i feel it rides better now with the lift springs in the rear.
  10. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I had one, it's firm, but it WILL flex pretty well
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    The first question everybody should have asked is.... What kind of wheeling do you plan on doing ?? If you're into rocks and a quality ride, I highly recomend BDS and Tuff Country springs. If your rear springs and in good condition, think ORD 4" Shackle Flip. I guess Rough Country would be okay for the mud pits, but it rides alittle rough for my back.
  12. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    I have the 4" springs. I removed the bottem leaf and they are softer now. They were taller but are still about 4". my rear springs were pretty sagged so with an echobit flip and a zero rate they are level to my 1 leaf removed front spring.
  13. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I have a 6" kit and as RJ said it will flex pretty well. Mine flexes well enough to smash the spring against the frame with minimal effort, I need longer front shackles. At first I had 6" springs in the front and an add-a-leaf and 4" block in the rear. I recently swapped the factory rear springs for 5.5" SkyJacker springs and a 1" zero rate. I think it rides fairly nice and flexes good.
  14. MountainMan
    MountainMan Registered Member
    Oct 9, 2000
    89
    Highlands Ranch, Colorado
    Good thread, good info, so I am also considering the 4" options out there, I have been partial to Skyjacker how does it compare to TC and also ProComp which i havent heard much about?
  15. MountainMan
    Oct 9, 2000
    89
    no good comparisons on the three lifts???
  16. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    out of all of the lift kits out there I would choose TC or BDS. /forums/images/graemlins/thumb.gif
  17. MountainMan
    Oct 9, 2000
    89
    BDS eh? that new to me, why that one?
  18. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    its costs just a little bit more and the ride is about the same but the springs have a LIFETIME warrenty so if anything happens to then they will replace them for FREE. /forums/images/graemlins/thumb.gif
  19. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    bds warrenty is "if it has our name on it and it break, we replace it."
    bds doesn't cost much more if any at all more than like TC.
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Every spring/suspension manufacturer offers a lifetime warranty. Read the fine print.
