rough country 4"lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KENNY, Jul 31, 2002.
  1. KENNY
    KENNY 1/2 ton status
    Dec 7, 2000
    292
    nyc
    rough country 4\"lift
    saw a 73 blazer with a 4" rough country lift and immediately wanted it on my truck. anyone have it and any suggestions. 84 blazer stock.
  2. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    Re: rough country 4\"lift
    Just put it on last weekend. ---- See the "OH MY GOD" posts for the whole story. I like it so far. The springs in the front were a little difficult and I needed a come-a-long to get then back on the axle.
    The rear was easy once I got the axle setup correctly - again, see the earlier posts.
    The springs were easy except the poly bushings were a little difficult. I had to use an arbor press but a vice would work fine. They delivered the lift kit on time and in good packaging.
    I do recommend you order new shackle bushings for the front and rear since you will have these items out anyway and the most likely need to be replaced anyway.
    Also, the lift comes with brake line extensions but order new steel brakeline first - you will be more happy. My brake lines are near their limit..
    The steering arm was easy but I had air tools. Overall, I like it so far but I have only been driving on it for a day.
    Chris
  3. Scott73
    Scott73 Registered Member
    May 22, 2002
    38
    Electra, TX
    I just received mine today and will put it on this weekend. I had the same lift on an '87 Chevy shortbed pickup for about 4 years and never had any problems. It had rear blocks. This time I went with springs all the way around. The Rough Country lift seems to be a tall 4" lift. Its closer to 5" than 4".
  4. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea thats the way im going..im going to try to go for all springs...cant wait! gatta get my damn body work done first though!! lol /forums/images/icons/smirk.gif
    Bryan
  5. loudnowlouder
    loudnowlouder 1/2 ton status
    Jan 29, 2001
    539
    Ellicott City, MD
    i've had the 4 inch rough country for over 2 years now...looks good, no noticable sagging...
    its real tall for a 4 incher in my opinion, at least the one i have is, 33s were way too tiny, and it rides kinda rough, but i'm sure its mostly due to the dual front shocks, one day i'll take one out to see the difference, just havent got around to it...
    but i had to lower my transfer case an inch to get the driveshaft from binding up and giving off a horrible noise....
    only took about 20 minutes to lower it and made a world of difference!
    check my info for pics, the lift was installed in all the pics...i need more pics with the 35s, but ever since i put em on it hasnt been running right
  6. KENNY
    Dec 7, 2000
    292
    nyc
    do i need a longer driveshaft, or any other parts
