Rough Country Lift Kits
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBadJap, Jun 5, 2003.
  1. BigBadJap
    BigBadJap Registered Member
    May 23, 2003
    76
    Alberta, Canada
    Hi, I'm looking at the Rough Country 4" lift kit w/rear springs.
    Anybody have/heard about this kit? Good/Bad/Ugly?
    It's for my daily driver which won't be be seeing alot of offroad.
    Also, can somebody kindly explain how a 52" rear spring would differ in ride from a 56" spring? (Does longer = softer ride?)
  2. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    i have this kit on my mainly offroad K5 and when i drove it after driving my other truck it scared me cuz they were so much softer than my other one. but then again my other one has 10 lift. i personally love it. it flexes great and gives a nice ride. but if u are looking for rid quality u might wanna look at BDS or something like that
    NITRO
  3. Polaris
    Polaris 1/2 ton status
    May 30, 2002
    1,182
    Rhinelander, Wisconsin
    I have that one with rear springs (no blocks). Mine is a daily driver/family vehicle but also goes off road often. It seems a little higher than 4" to me. I did need the extended rear brake line and the front driveshaft spacer. Performance wise it is just fine. Not so rough as other people say, in my opinion. I don't have experience with anything else, though. My truck rides like a truck. Go with 52" springs, because that is what you have. 56" springs if I'm not mistaken were in some 3/4 ton and 1 ton pickups. Follow the "My K5" link below to see my truck doing a little flexing when we were out wheeling about a month ago. That is with the swaybar still on. I'd say go for it!
  4. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    I second that motion. I have the exact kit and love it. It rides awesome on and offroad and flexes nicely. Hit it up! /forums/images/graemlins/truck.gif
  5. Catman
    Catman Registered Member
    Feb 4, 2003
    53
    Yucca Valley, Calif.
    I put the exact same kit on my 90 K5 and have no regrets. It is more like 5" but that's cool. As for the rough ride.....I've spent 37 years riding Harleys. Suspension is just a state of mind! /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/thumb.gif
  6. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    yeap, its a damn nice kit, dosnt include hardware, so you will have to get some new leaf eye bolts, but the kit is very complete other wise, and is worth the money. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  7. BigBadJap
    May 23, 2003
    76
    Alberta, Canada
    Any gripes with this kit? Like missing parts, bad machining, poor instructions?
    Will I "NEED" a front driveshaft spacer and extended brake lines?
  8. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Like (borregoK5) told me once on here; "You can run a 4" lift without any major mods, but if you want to run it well, you will need to make the same modifications as a 6" mod." Which basically means you could probably get away with a 4" lift with pretty much stock everything, except shocks. You might have a vibe or two, and break some u-joints. But if you dont want to have to worry about that stuff, you need to do everything you would to a 6" lift like longer driveshaft, shimms or cv shaft, extended brake lines, etc, etc...
    -Harrison
  9. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    I had to get my rear driveshaft lengthened. The PO had put the lift on and not lengthened it. Within about 100 miles, it backed off the case yoke nut and it dropped the whole shaft with yoke off the case. /forums/images/graemlins/shocked.gif
    As with any springs, re-tighten the u-bolts nuts a few times after you're done. Mine had loosened to almost finger tight.
    I think you're going to have to lengthen brake lines too. Luckily that was something the PO had done. My parking brake cable also needs to be lengthened (haven't done that yet).
    Do a search. Rough country springs were just covered in a thread not long ago.
  10. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    If you're gonna do it, do it right. Suspension is like brakes, you don't want to go cheap on it.
    You'll need a raised steering arm, which the RC 4" kit does not include.
    Another thin you might like are some braided stainless-steel brake lines. They don't swell as much as stock ones under hard braking and give plenty of room for flexing.
    Your front driveshaft will be too short, so you will need the Superlift front driveshaft spacer.
    I did all this to my truck for the 4" Skyjacker, Grand cost was $553...I couldn't be happier, except for if I had just gone for the 6" in the first place, but a body lift made up for it.
  11. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    /forums/images/graemlins/thinking.gif wanna try again? The rough country kit i got for 459, even the one they sell for 295 comes with a rasised steering arm and a new cotter pin, and 3 new torq nuts, goto www.roughcountry.com and check the products out, call them for them to answer your questions. /forums/images/graemlins/thumb.gif
  12. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Was looking at their ad in Peterson's...it doesn't say it includes the arm... oh well, great then, that's one less thing you have to buy
  13. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I just bought a RC 4" lift w/ blocks. I haven't installed it yet, but it came with everything to put it on. Brake line extensions (not gonna use them), the steering arm, nuts, bolts, shocks, shock boots... Seemed complete to me for $295 I'm happy with it /forums/images/graemlins/grin.gif
