rough country lift question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kumma, Oct 2, 2001.
  1. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    i need some info on my rough country 4" lift, figured you guys could reply quicker than the company.
    shocks - longer set on front or back?
    springs - does rear shim short side facing front or rear?
    craig
    "Why is there a <font color=red>watermelon</font color=red> here?"
  2. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    I'm not sure what the rear shim is? Can't remember where the longer shocks go? Make sure you put them in with the cylinder down though. I'll take a look at my rig when I go home and see about the length.
  3. taterblazer
    Feb 2, 2001
    277
    Boise, ID
    Smack on the fore head!
    The rear shim thin side goes towards the front raising the pinion toward the transfer case.
  4. surg82k5
    surg82k5 1/2 ton status
    Feb 7, 2001
    416
    San Antonio,Texas
    The smaller side of the shim will go towards the front of the vehicle, as far as shocks I am pretty sure that the longer ones will go on back, it should say on one of the paper lists that you got with the kit. It will give you the number that is on the shock and they state front or rear shock. I think it is the sheet that tells you to make sure you have everything in the kit. Hope this helps.
    Sergio
    Check out my new website. <a target="_blank" href=http://www.surg82k5.rockcrawler.com>http://www.surg82k5.rockcrawler.com</a>
  5. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Longer shocks always go on the back.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  6. kumma
    Oct 29, 2000
    380
    Novi, Michigan
    thanks for the answers, i would have consulted the sheet they sent but like my mind and money it went missing.
