ROUGH IDLE AFTER WARMING UP
Discussion in '1982-Present GM Diesel' started by ringer, May 28, 2004.
  1. ringer
    ringer Registered Member
    May 26, 2004
    12
    Hi all,
    New to the forum and new to diesels as well.
    I have a new to me 1985 3/4 ton Chevy Suburban 6.2L diesel 4x4 with a three-speed tranny and NP 208 transfer case. 119,000 miles.
    The truck runs great at first(fires up easily) but as the day wears on, the idle gets rough, so rough I get a bit of shaking in the truck. There is no smoke that I can see either at idle or at speed/acceleration. I also seem to be losing power as the day goes on.
    I have changed the fuel filter. Is it an injector?? I just need some idea on where to start. Thanks in advance!
    Mike
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Im still learning about these diesels myself.
    my uneducated guess says that perhaps your not getting fuel delivery anymore-
    How does it run on the highway?
  3. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    here are my thought's
    either the lift pump ( my 1st bet )
    or the injector pump
    as the engine gets hotter the rubber seals are letting air in or not pumping properly
    I recomend ya put a in line LOW PRESSURE electric pump in and see if that fixs it ( cheep and easy ) and even f it dont its a great feature to have I.M.O.
    BEST OF LUCK
    WELCOME !!!!!
    R
  4. ringer
    May 26, 2004
    12
    TY for the responses guys!
    The truck runs ok on the highway, but seems short on power. However, as mentioned, this is my first diesel and I am not sure of how it should feel.
    I do know, it is "missing". In park with a litte fuel, there is a pronounced shudder to the engine that smooths out a bit at higher rpms.
