rough idle speed performance, 92 s-10 4.3L TBI
Discussion in 'Other Rides' started by R72K5, May 18, 2004.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i need to know of anything that may or is known to cause erratic and variable idling speeds/bad idle performance on a 92 s-10 4.3L TBI engine, so far we put new fuel pump in and replaced wiriing harness from the distributor to the coil and also the spark plugs and i cleaned off all the carbon that was on the IAC motor and hole for it in the TBI unit
    truck otherwise runs great all other RPM's andc on the freeway except now and then it will bog out for a couple seconds when are traveling constant speed ont he freeway, as if its dying shutting off and then it will just out of the blue regain RPM and keep on going like nothing ever happened, when it does this then the check guages and the check engine light both come on, otherwise only the guages light comes on now and then for only a few seconds
    thanks for anything
  2. 4by4bygod
    4by4bygod 1/2 ton status
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    You might have a bad EGR valve. That wil cause it to idle very rough, but still run good on the highway.
    Tom /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    How old are the spark plug wires, i had a similar problem with our 1/2 ton truck with the 4.3, replaced the cap,rotor,plugs,filters,coil, and still had the problem, finally, i changed out the "factory original" plug wires and it was cured, seems we had one grounding out behind the motor somewhere.
    Being that the 4.3 is only a 6 cylinder, if you drop even one, it will dog out on ya big time.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    thought about that so i went ahead and plugged the vacuum source to it, diidnt change anything so far.
    thanks /forums/images/graemlins/laugh.gif
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    wires and plugs are replacement i know, weve prety much been all over the entire engine, even have dropped the fuel tank a few times but gota do it once again to replce the fuel sender unit and the pump with nw parts
